Aruba MC3600 Remote AP Max Capacity
  • 1.  Aruba MC3600 Remote AP Max Capacity
    Posted Dec 02, 2015 10:00 PM
    Hi Guys, currently I'm using MC3600 with AOS 5.0. I have about 300 units of remote AP terminating in the controller as the max capacity of RAP for MC3600 is 512.
    My question is does Aruba MC3600 still supporting 512 remote AP in AOS 6.1 - 6.3 after upgraded?
    Thanks!
  • 2.  RE: Aruba MC3600 Remote AP Max Capacity
    Posted Dec 03, 2015 06:25 AM
    It does not support the 4:1 radio when you upgrade, no.
  • 3.  RE: Aruba MC3600 Remote AP Max Capacity
    Posted Dec 03, 2015 11:32 AM
    The recent 7xxx controllers doesn't support the 1:4 ration.
    But I thing the 3xxx series still support the 1:4 ratio.
    See attached matrix.
    Colin, please confirm.
    Rajaguru Vincent
    Attachment(s)
  • 4.  RE: Aruba MC3600 Remote AP Max Capacity
    Posted Dec 03, 2015 11:52 AM
    rvincent, you are correct.  My bad.  Thank you.
  • 5.  RE: Aruba MC3600 Remote AP Max Capacity
    Posted Dec 10, 2015 05:38 AM
    Hi rvincent,
    this 1:4 ratio is not restricted by any AOS version right? as long as it is MC3000 series.
  • 6.  RE: Aruba MC3600 Remote AP Max Capacity
    Posted Dec 20, 2015 10:49 AM
    [edit] nevermind
