Aruba Meridian
  • 1.  Aruba Meridian
    Posted Aug 05, 2013 03:04 AM
    can anyone tell me, is Meridian a multi-vendor system or not?
    #Meridian
    #ALE
    #LocationServices
  • 2.  RE: Aruba Meridian
    Posted Aug 05, 2013 07:00 AM
    yep...as far as i aware,it is multi vendor.
  • 3.  RE: Aruba Meridian
    Posted Aug 05, 2013 07:56 AM
    Multi-vendor in terms of what per se?  WLAN environment?
  • 4.  RE: Aruba Meridian
    Posted Aug 05, 2013 08:08 AM
    I mean, is it possible to deploy Meridian on non-Aruba devices (Cisco, Motorola, HP for example)?
  • 5.  RE: Aruba Meridian
    Posted Aug 05, 2013 09:36 AM
    Without using any wireless, Meridian can provide an application and way finding features. In this mode, Meridian functions as a way-finding turn by turn application, without referencing wireless location.
    With an underlying WLAN, it is supported with Aruba's ALE engine (analystics and location engine) which will provide a much richer experience.  Meridian, before Aruba's aquisition, interfaced with Cisco's MSE as a licensable option.
  • 6.  RE: Aruba Meridian
    Posted Aug 05, 2013 09:58 AM
    Ok, Thank you.
    I was talking about wireless networks.
    Can I find any list of supported vendors (which provide wireless networks) to integrate with Meridian?
    And one more question: is it possible to integrate Cisco (I mean Cisco wireless infrustructure) with Aruba Meridian (without Aruba AP and Aruba controller)?
  • 7.  RE: Aruba Meridian
    Posted Aug 05, 2013 11:01 AM
    from the following address:
    http://www.meridianapps.com/cisco
    regarding other wireless vendors..you should wait to a full product release from Aruba - because all the info (on that site)  is before Aruba bought this software soultion..
  • 8.  RE: Aruba Meridian
    Posted Oct 09, 2013 10:06 AM
    There should be a huge RED X on Cisco on that image :)
