Aruba MIBs returning incorrect AP Names
  • 1.  Aruba MIBs returning incorrect AP Names
    Posted Dec 11, 2014 04:10 PM
    I am trying to Monitor our Aruba wireless network with Nagios and am having a problem with the data the Aruba MIBs are returning...
    Specicially, when I snmp walk a controller using the Aruba MIBs to find a specific AP, most of the info returned looks like:
    WLSX-SWITCH-MIB::staUserName.'..{O..'.'...}`p' = STRING:
    Instead of a human readable name, it returns with that odd string ('..{O..'.'...}`p')
    Here is the same line when just using the standard SNMPv2
    SNMPv2-SMI::enterprises.14823.2.2.1.1.2.2.1.6.0.18.123.79.196.169.0.11.134.125.96.112 = ""
    It also looks like using the SNMPv2-SMI MIB, most of the same data is returned, so at this point it is easer to not use the Aruba MIBs but not ideal.  Has anyone else had this issue or not what may be causing it?
    Cheers
  • 2.  RE: Aruba MIBs returning incorrect AP Names
    Posted Dec 13, 2014 01:57 AM
    Oxy-Mike
    add -O0X  (dash OH-zero-X)  to the snmpwalk command, i.e.
    root@kali:/home/aruba/mibs/6.3.1.2# snmpwalk -v2c -c public -mALL -M. -O0X  c7030 .1.3.6.1.4.1.14823.2.2.1.5.2.1.7.1.9
    WLSX-WLAN-MIB::wlanAPBssidUpTime[STRING: 00:24:6c:ca:24:78][1][STRING: 00:24:6c:22:47:88] = Timeticks: (1448700) 4:01:27.00
    regards
    -jeff
  • 3.  RE: Aruba MIBs returning incorrect AP Names
    Posted Dec 15, 2014 03:59 PM
    Perfect, thank you!
  • 4.  RE: Aruba MIBs returning incorrect AP Names
    Posted Jan 14, 2015 02:19 PM
    I have one more question, I am haivng a problem using snmpget to poll a specific AP.
    As an exapmle, I would like to get the SNR of an AP...  When I ran snmpwalk, the first AP in the list looked like this:
    WLSX-SWITCH-MIB::staSignalToNoiseRatio[STRING: 00:12:7b:4f:c4:a9][STRING: 00:0b:86:7d:60:70] = INTEGER: 12
    I cannot use the above output for snmpget becuase of the formatting of "[STRING: 00:12:7b:4f:c4:a9][STRING: 00:0b:86:7d:60:70]".
    Can someone help me with with the correct snmpget command for that AP?
  • 5.  RE: Aruba MIBs returning incorrect AP Names
    Posted Jan 14, 2015 09:17 PM
    change it back to dotted format using -On flag instead of -O0X
    root@bt:/home/aruba/mibs/6.4.2.x# snmpwalk -v2c -c public -M. -mALL -O0X 192.168.1.254 staSignalToNoiseRatio
    WLSX-SWITCH-MIB::staSignalToNoiseRatio[STRING: 24:77:03:1f:54:90][STRING: ac:a3:1e:b7:df:30] = INTEGER: 55
    root@bt:/home/aruba/mibs/6.4.2.x# snmpwalk -v2c -c public -M. -mALL -On 192.168.1.254 staSignalToNoiseRatio
    .1.3.6.1.4.1.14823.2.2.1.1.2.2.1.7.36.119.3.31.84.144.172.163.30.183.223.48 = INTEGER: 55
    root@bt:/home/aruba/mibs/6.4.2.x# snmpget -v2c -c public 192.168.1.254 .1.3.6.1.4.1.14823.2.2.1.1.2.2.1.7.36.119.3.31.84.144.172.163.30.183.223.48
    SNMPv2-SMI::enterprises.14823.2.2.1.1.2.2.1.7.36.119.3.31.84.144.172.163.30.183.223.48 = INTEGER: 55
    also can use -O0X in the snmpget to make it readable again:
    root@bt:/home/aruba/mibs/6.4.2.x# snmpget -v2c -c public -O0X -M. -mALL 192.168.1.254 .1.3.6.1.4.1.14823.2.2.1.1.2.2.1.7.36.119.3.31.84.144.172.163.30.183.223.48
    WLSX-SWITCH-MIB::staSignalToNoiseRatio[STRING: 24:77:03:1f:54:90][STRING: ac:a3:1e:b7:df:30] = INTEGER: 53
    hth
    -jeff
