Could it be that the AP is not supported under 8.6?
Have not heard this behavior. If the APs are supported in both 8.6 and 8.9, the fastest resolution is probably to work with Aruba support.
Original Message:
Sent: Sep 26, 2022 04:25 AM
Subject: Aruba MM does not show Access Point on AOS8.6
Hi, My MM does not show Access Points for AOS8.6
But working well with AOS8.9
I had tested it with same configuration but different AOS
Is it a bug?
