Aruba MM HD Size
  • 1.  Aruba MM HD Size
    Posted Sep 04, 2017 02:38 PM
    Hi
    Can someone explain me how can I find the size of the HDD provisoned on the VM I used to configured my Mobility Master?
    I started with a HDD1 and HDD of 8GB each and in order to test the procces, I requsted to mt VM team expan HDD to 10G but I don't know how I can interpreate the values from the cli of the MM
    (WLAN-MM01) *[/] #show storage
    Filesystem Size Used Available Use% Mounted on
    none 3.0G 11.7M 3.0G 0% /tmp
    /dev/sdb1 5.8G 2.0G 3.5G 36% /flash
    /dev/sda5 1.4G 381.3M 1021.7M 27% /mnt/disk1
    /dev/sda6 1.4G 381.3M 1021.7M 27% /mnt/disk2
    (WLAN-MM01) *[/] #
    Antonio
  • 2.  RE: Aruba MM HD Size
    Posted Sep 06, 2017 08:17 AM
    The Show Storage is similar to the df command on linux :
    Filesystem      Size  Used Avail Use% Mounted on
    /dev/loop0       18G   15G  2.5G  86% /
    none            4.0K     0  4.0K   0% /sys/fs/cgroup
    udev            483M  4.0K  483M   1% /dev
    tmpfs            99M  1.4M   97M   2% /run
    none            5.0M     0  5.0M   0% /run/lock
    none            492M  1.8M  490M   1% /run/shm
    none            100M   20K  100M   1% /run/user
    /dev/sda3       167G  157G  9.9G  95% /host
  • 3.  RE: Aruba MM HD Size
    Posted Sep 12, 2017 03:14 PM
    As far as I can see, both disks are to storage the boot images sor for the Mobility Master.
    /dev/sdb1 this is the files available in directory(we can check this by using the command: #dir)
    /dev/sdb5 this is boot partition 0:0
    /dev/sdb6 this is boot partition 0:1
    (EU-WLAN-MM01) [mynode] #show storage
    none                      3.0G     28.9M      3.0G   1% /tmp
    /dev/sdb1                 5.8G      1.7G      3.8G  31% /flash
    (EU-WLAN-MM01) [mynode] #show image
    version                 Show System image version information
    (EU-WLAN-MM01) [mynode] #show image version
    Partition               : 0:0 (/mnt/disk1)
    Software Version        : ArubaOS 8.1.0.1 (Digitally Signed SHA1/SHA256 - Production Build)
    Build number            : 59688
    Label                   : 59688
    Built on                : Thu May 18 20:22:32 UTC 2017
    Partition               : 0:1 (/mnt/disk2) **Default boot**
    Software Version        : ArubaOS 8.1.0.2 (Digitally Signed SHA1/SHA256 - Production Build)
    Build number            : 60858
    Label                   : 60858
    Built on                : Sun Aug 6 02:02:47 UTC 2017
  • 4.  RE: Aruba MM HD Size
    Posted Sep 12, 2017 03:24 PM
    What are you trying to do?
  • 5.  RE: Aruba MM HD Size
    Posted Sep 12, 2017 03:36 PM
    I want to understand the file system on the MM before I migrate all my enviroment from 6.5 to 8.0. According to the ArubaOS requiments to run a MM-500 I need 8GB disk and for a MM-5K I would need 16GB so I want to undersdtand how the capcity will be used.
  • 6.  RE: Aruba MM HD Size
    Posted Sep 12, 2017 06:36 PM
    Check the latest AOS 8.1 installation guide, I believe the disk size requirements changed (you are likely looking at the AOS 8.0 sizing numbers, which were increased for AOS 8.1+).
    MM-VA-500 = 8GB Disk
    MM-VA-1K = 32GB
    MM-VA-5K = 64GB
    MM-VA-10K = 128GB
    As far as the disks setup on the ESX host, there are two hard disks created. One will be 4GB which is Hard Disk 1 and is where the base OS / firmware is for subsequent images (think wr erase all). The other Hard Disk 2 will be the live disks where the two partitions, flash, etc will be.
  • 7.  RE: Aruba MM HD Size
    Posted Sep 13, 2017 12:29 AM
    Thanks for the clarification. So can I delete the 4GB HD1 on my ESXi host then?
  • 8.  RE: Aruba MM HD Size
    Posted Sep 13, 2017 08:54 AM
    No, that HD is your backup partition should you need to migrate or recover from a wr erase. Everything on the ESX VM is required and should not be deleted.
  • 9.  RE: Aruba MM HD Size
