Aruba MM-MC operations
  • 1.  Aruba MM-MC operations
    Posted Jun 25, 2018 07:22 AM
    I am sure option C is incorrect, and option A seems to be the correct one. Please advise
  • 2.  RE: Aruba MM-MC operations
    Posted Jun 25, 2018 07:30 AM
    Option A is correct.  Please take a look at the ArubaOS 8 Fundamentals Guide here:  http://community.arubanetworks.com/t5/Controller-Based-WLANs/ArubaOS-8-Fundamentals-Guide/ta-p/428914 for more answers.
  • 3.  RE: Aruba MM-MC operations
    Posted Jun 25, 2018 04:26 PM
    Hi guys,
    I don't think it is wise to ask these questions. It is against Aruba Policy!
  • 4.  RE: Aruba MM-MC operations
    Posted Jun 25, 2018 10:32 PM
    Generally yes, and especially if that is screenshot from an actual test. If it's from a practice exam, it's less risky but the answer is 'A' for sure.
    B - MM uses AirMatch, not ARM
    C - MM will NOT ever terminate APs
    D - In AOS 8, with an MM, no MC will do local config
  • 5.  RE: Aruba MM-MC operations
    Posted Jun 28, 2018 01:17 AM
    Hi Guys can anyone tell me how do it upgrade Aruba airmatch, will it happen
    through global upgrade or as a separate LSM upgrade??
  • 6.  RE: Aruba MM-MC operations
    Posted Jun 28, 2018 01:48 AM
    As far as I know at the moment it is included on the MM and will upgrade with the upgrade of the MM
  • 7.  RE: Aruba MM-MC operations
    Posted Jun 28, 2018 08:43 AM
    It happens with an upgrade of the MM. It can be upgraded with an LSM.
  • 8.  RE: Aruba MM-MC operations
    Posted Jun 25, 2018 10:42 PM
    Thanks Buddy, that was testking. I could see many wrong answers in them.
