Aruba MM SSID PSK - Clearpass - MAB - Endpoint Repository
This thread has been viewed 16 times
  • 1.  Aruba MM SSID PSK - Clearpass - MAB - Endpoint Repository
    Posted Dec 19, 2020 10:03 AM
    Hi All,
    I have couple Chromecast that I was planning to put in the SSID IOT with users in SSID Corp. Sadly I read that it is not possible to screen to a chrome cast from a different SSID. So, I had the idea to create a new SSID named casting.
    My Corp SSID is configured as follow:
     - WPA 2 Enterprise
    -- Services with PEAP and TLS enabled
    -- RoleMapping AD group for users mapped to role users and AD group for guests mapped to role guest
    -- Enforcement TLS + role users VLAN 44
    -- Enforcement PEAP + role users VLAN 41
    -- Enforcement PEAP + role guests VLAN 43
    Second SSID is IOT and this is configured as follow:
    - WPA 2 Personal MPSK
    -- Services Allow ALL MAC with Guest Device Repository
    -- Enforcement VLAN 42
    My idea for the third SSID Casting was as follow:
    - WPA 2 Personal, with MAC auth enabled
    -- Services Allow ALL MAC with Endpoints Repository
    -- Rolemapping that the endpoint status need to be known
    -- Enforcement that the endpoint group is casting and force Guest VLAN 43
    However, status stays logon (default role)
    What do I miss in my configuration?
    Mark Raats
    CWNE #290
    Goal 2021: ACMA, ACCA
  • 2.  RE: Aruba MM SSID PSK - Clearpass - MAB - Endpoint Repository
    MVP EXPERT
    Posted Dec 19, 2020 03:42 PM
    Hi Mark,
    I have two SSID's with the same VLAN ID and casting is working fine. When cast to another VLAN you need a multicast router to forward mulitcast traffic (afaik, igmp snooping on your edgeswitch should work), without a multicast router  your multicast edge is the broadcast domein (VLAN).
    Marcel Koedijk | MVP Expert 2020 | ACMP | ACCP | Ekahau ECSE
