Aruba MM-VA and HW controller redundancy
  • 1.  Aruba MM-VA and HW controller redundancy
    Posted Dec 11, 2018 09:58 AM
    Hi ALL
    i need to install in main site to MM-VA controllers that act as
    mm-master and mm-backup and in local branches (10 sites)
    need to install HW controller 7010 model that will synch from and to
    the MM-VA for licence and configuration ...
    1- this scenario valid?
    2-if no what is my option?
    3-if yes .. can you please explain how ? (vrrp ?LMS)
    because i very confused when i turn on the controler what mode i need to choose if i want the controler to be MD ?
    it will very help me if you can post a exmpale .
    BR Avi
  • 2.  RE: Aruba MM-VA and HW controller redundancy
    Posted Dec 11, 2018 10:11 AM
    If I understand you correct, you would first install the the 2 MM-VAs at a central site with a VRRP between them to manage the configuration and licensing of all of your 7010s.  Later when you configure the 7010s, they should be MDs (controllers that serve access points and clients) and point them to the VRRP ip address between the 2 MM-VAs.  You would add the licenses to the MM-VAs.
    Have you seen the ArubaOS 8 fundamentals guide here?  https://community.arubanetworks.com/t5/Controller-Based-WLANs/ArubaOS-8-Fundamentals-Guide/ta-p/428914
    Also please look at the ArubaOS 8.2 videos below.
  • 3.  RE: Aruba MM-VA and HW controller redundancy
    Posted Dec 12, 2018 08:32 AM
    Hi
    i read the guides and still i am very confused...
    when i turn on  from the box the controller in wich mode should i pick for
    MD ?
    can somone print the cli command for enter or config MD to manage in the MM ?
    i get how to config and i config in the past two contrroller in mobility mastery/mobility backup ,ode with VRRP and its working graet BUT
    the MM and MD i not understand yet...
    Br Avi
  • 4.  RE: Aruba MM-VA and HW controller redundancy
    Posted Dec 12, 2018 09:29 AM
    Following these instructions :
    How to deploy Mobility Master
    https://ase.arubanetworks.com/solutions/id/139
    How to deploy MM and Backup MM
    https://ase.arubanetworks.com/solutions/id/146
    Licensing
    https://ase.arubanetworks.com/solutions/id/154
    How to add Mobility Controllers in the MM
    https://ase.arubanetworks.com/solutions/id/153
    Thank you
    Victor Fabian
    Pardon typos sent from Mobile
  • 5.  RE: Aruba MM-VA and HW controller redundancy
    Posted Dec 13, 2018 08:18 AM
    Thanks its working
    now how i add IAP to MD ?
    i enter the instant and converting and then i config the ip of the MD controller and its not working ..
    what i doing wrong.. ?
  • 6.  RE: Aruba MM-VA and HW controller redundancy
    Posted Dec 13, 2018 08:38 AM
    Configure the Configuration > “default” AP group > LMS to point to the controller mgmt IP Address
    Thank you
    Victor Fabian
  • 7.  RE: Aruba MM-VA and HW controller redundancy
    Posted Dec 13, 2018 09:15 AM
    Hi Victor
    i config in the MD the lms ip and connect the ap directly to the controller
    and then enter to the iap and direct to the MD ip and still not working ..
    i miss somthing ?
  • 8.  RE: Aruba MM-VA and HW controller redundancy
    Posted Dec 13, 2018 10:28 AM
    Are you able to see the controller?
    Did you apply the licenses ?
    Can you ping the controller from the AP network ?
    Do you see any alerts (error messages) at the top ?
    Thank you
    Victor Fabian
  • 9.  RE: Aruba MM-VA and HW controller redundancy
    Posted Dec 13, 2018 10:28 PM
    Hi Victor
    First Thank you.
    i set the net in my lab first and only for the tests the MM-VA and the MD
    are on the same Lan , in the MM i see the controller and its ok i installed global license .
    can you please tell me what is the procedure when you what to connect iap to this setup?(MM and MD)
  • 10.  RE: Aruba MM-VA and HW controller redundancy
    Posted Dec 16, 2018 04:45 AM
    Hi
    now its working because when i connected directly to wired port
    int the MD controller i need to authenticate and thats the reason why
    the AP fail to connect the controller .
    BUT how can i fix this issue i dont want wired client authenticated at all .
    i want that the MD controller switch port will be open .
    how can i fix this ?
    THANKS .
  • 11.  RE: Aruba MM-VA and HW controller redundancy
    Posted Dec 16, 2018 07:15 AM
    In the MD on that interface it should be "trusted"
  • 12.  RE: Aruba MM-VA and HW controller redundancy
    Posted Dec 16, 2018 07:54 AM
    Thanks All for your Help !!
    its working great forum .
  • 13.  RE: Aruba MM-VA and HW controller redundancy
    Posted Dec 17, 2018 10:05 PM
    ___________________________________________
    Redtube Beeg Spankbang
  • 14.  RE: Aruba MM-VA and HW controller redundancy
