Aruba mobility cluster high value traffic classification
  • 1.  Aruba mobility cluster high value traffic classification
    Posted Jun 11, 2018 02:46 AM
    how/when/where is the high value traffic classified by the mobility controller in order to be synchronised to standby cluster member ? can the classification be changed ?
  • 2.  RE: Aruba mobility cluster high value traffic classification
    Posted Jun 11, 2018 11:05 AM
    High value sessions are only synchronized in an L2-connected cluster of mobility controllers. If the cluster is L3-connected, then sessions can not be synchronized.
    The synchronization is automatic for an L2-connected cluster.
    High value sessions are TCP connections like FTP. It should be noted that where priority and/or TOS is changed, or the session is DPI-modified, it becomes a high-value session. So voice going through an ALG, for instance, would be high-value.
  • 3.  RE: Aruba mobility cluster high value traffic classification
    Posted Jun 12, 2018 04:55 AM
    Hello Charlie,
    My cluster is L2-Connected.
    I can see that my FTP sessions are high value session by default. I tried the same with SSH but the sessions are not classified as high value session by default. I then added a policy for the assigned role to change priority / TOS value for all my SSH sessions. The assigment of the priority / TOS value can be seen with sh datapath session and confirms that the policy is working. Unfortunately I can still not see the SSH sessions synchronized to standby or assigned as high value sessions (sh datapath session high-value). We are running version 8.3.0.0.
    Thanks for any feedback.
  • 4.  RE: Aruba mobility cluster high value traffic classification
    Posted Oct 08, 2018 11:46 PM
    I have also witnessed this situation on arubaos 8.3.0.2, but there is a solution.
    I tried setting SSH as "high priority" and as TOS=46 for example but here is no "h" in the datapath session and it is not sychronized to the other L2 cluster members.
    I has used a rule as such
    any any svc-ssh permit queue high tos 46 position 1
    intially expecting that to work, but it did not....
    i managed to solve the problem by changing the rule to this instead:
    any any app ssh permit queue high tos 46 position 1
    i believe this is not a bug but in fact how it should be working.
    you must use rule type "app" instead of "access-control" to enable the "high value" feature set.  Also, setting tos=x does not seem required, simply setting queue=high seemed to get me the desired "high value" determination.
    I hope this helps
    Neal Vadekar
  • 5.  RE: Aruba mobility cluster high value traffic classification
    Posted Oct 12, 2019 11:08 AM
    What command do you use to confirm it was being synchronized to S-UAC?
    show datapath session
    show datapath session high-value
    I've tried to set an app rule for ICMP as a test and I can get it flagged as high-value. Argh
