last person joined: 5 hours ago
Aruba Model 275 Access Points
  • 1.  Aruba Model 275 Access Points
    Posted Apr 22, 2021 05:50 PM
    Hello  all,
    Can anyone point me in the direction to see where I might find documentation on if there is a limitation where channels have to be statically set to be able to have these outdoor APs set to max power? I have a deployment where the outdoor APs need to bet set to max power, but the channels are being statically set. ARM is enabled on the cluster.  Another vendor is telling me that is the limitation.
    Ledell Green
  • 2.  RE: Aruba Model 275 Access Points
    Posted Apr 23, 2021 02:12 AM
    you should be able to set static channels from there
