SD-WAN
  • 1.  Aruba native SDWAN solution query
    Posted May 29, 2024 04:26 AM
    Dear Experts,
    I am not referring to Silverpeaks. Aruba has its SD-WAN solution as well. Can someone tell me if they have built an EVE-NG lab using it?
  • 2.  RE: Aruba native SDWAN solution query
    Posted May 29, 2024 08:57 AM
    SD-Branch works on ArubaOS/AOS gateways. I'm not aware of virtual support in EVE-NG for it.
  • 3.  RE: Aruba native SDWAN solution query
    Posted May 30, 2024 04:28 AM
    so you mean we cant have VMC as a gateway for sd-branch?
  • 4.  RE: Aruba native SDWAN solution query
    Posted May 30, 2024 07:54 AM
    If I'm correct there are only VMC as VPNC in SD-Branch; not VMC as gateway.
  • 5.  RE: Aruba native SDWAN solution query
    Posted May 30, 2024 08:48 AM
    In my lab i have 7005 controller, can it act as a gateway
  • 6.  RE: Aruba native SDWAN solution query
    Posted May 30, 2024 10:12 AM
    Yes, 7005 can work as SD-Branch gateway.
