I am working in NetEdit on version 2.0.2 and i have a problem with a TACACS configuration when deploying a configuration plan.
In fact, during validation before deployment, the entire configuration is considered to be "invalid input".
In addition, the reading works because the devices have the status "OK" and NAE "Normal".
TACACS accepts REST & SSH access well.
(the credentials for tacacs are correctly entered in NetEdit)
The problem does not occur in a local users + TACACS OFF configuration
Do you have a solution, a workaround ?
