Wired
Aruba NetEdit 2.1 Released!
This thread has been viewed 29 times
  • 1.  Aruba NetEdit 2.1 Released!
    Posted Apr 26, 2021 05:32 AM
    NetEdit 2.1 release Highlights:
    1. TACACS support of user accounts
    2. NAE deployment with Solution Config
    3. Improved Network Device Discover: CSV File Import
    4. Fabric Composer Cross Launch
    Step1: Add reachable TACACS server  (like clearpass)
    Step2: Configure profile, policies and services on reachable TACACS Server (like Clearpass).
    Authentication
    –Add netedit user (admin/technician) to TACACS/AAA server
    If it is Clearpass,
    –add to local users list under Identity
    –Also add netedit to device list under Network
    Authorization
    Create an admin and technician profile with right privilege level.
    Admin = 15
    Technician = 1
    Add them to policies.
    Create TACACS Service attach policy
    Centralized NAE agent deployment on to AOS-CX switches
    File .CSV is must
    4. AFC Integration
    Discover AFC switches through Aruba NetEdit!
    More information:
    Aruba Support Portal
    Good day!
    Yash NN
  • 2.  RE: Aruba NetEdit 2.1 Released!
    Posted Apr 27, 2021 04:56 AM
    Thanks.
    In the screenshot there are 2 "admin" username instances: is it expected ?
    Vincent Giles
  • 3.  RE: Aruba NetEdit 2.1 Released!
    Posted Apr 27, 2021 07:31 AM
    Good observation Vincent!
    As you see in above screenshot both (admin) are not active. It was test case to check admin as real local administrator and another as technician from TACACS.
    • In short: Always local 'admin' user will be given highest priority. In otherwords, if admin user is configured on locally and tacacs, locally configured admin will be prioritized.
    Good day!
    Yash NN
  • 4.  RE: Aruba NetEdit 2.1 Released!
    Posted May 07, 2021 02:47 AM
    NetEdit 2.1 documentation
    Yash NN
