Wired Intelligent Edge
Aruba NetEdit Devices unreachable
This thread has been viewed 36 times
  • 1.  Aruba NetEdit Devices unreachable
    Posted Aug 09, 2022 02:01 PM
    Hi Community,
    I made a lab on eve-ng to prepare netedit with aruba cx,
    I can ping to server but the devices showing unreachable on netedit
    Can anyone help me or have an idea about the issue?
    MohammedEL MACHTI
  • 2.  RE: Aruba NetEdit Devices unreachable
    Posted Aug 10, 2022 08:36 AM
    Hi
    In NetEdit under Settings ->Device Credential you are saving the credentials for the switches that have the be managed. There are 3 types of credentials, REST, SSH and SNMP. For ArubaOS-CX switches it is mandatory to have REST credentials, otherwise the connection will not work. Please configure REST credentials if not already done. REST access is possible via the default admin account, which is also used for SSH and webUI access.
  • 3.  RE: Aruba NetEdit Devices unreachable
    Posted Aug 12, 2022 08:37 PM
    Hi Emil,
    Thank you for replay,
    i think im configure the rest access for the switch
    https-server rest access-mode read-write
    https-server vrf default
    https-server vrf mgmt
    SW-B# show https-server
    HTTPS Server Configuration
    VRF : default, mgmt
    REST Access Mode : read-write
    ANY advice please
    regards
    MohammedEL MACHTI
  • 4.  RE: Aruba NetEdit Devices unreachable
    Posted Aug 13, 2022 10:04 AM
    OK, my suspect is not correct here. You have configured REST credentials, I assume the password matches the admin password of the switches.
    You mention that you can ping the server. Does it mean you can ping from the CLI of every switch in vrf mgmt the IP of the netedit 10.1.1.246? Can you also ping the switches from the bash shell of netedit?
    Are the switches in this state since the first discovery? Or they were available for a short time? If they were available before did they become unreachable after you did a config change?
    Please go to the tab LOGs and try to identify if there are any errors logged after the discovery of the switches?
    Or in tab LOGS you can go to action and enable debug logging. Then try to delete and discover again the switches. Check the log for any error messages if the status is unreachable again.
  • 5.  RE: Aruba NetEdit Devices unreachable
    Posted Aug 13, 2022 01:07 PM
    Thank you emil I appreciate that,
    I think the reason is that the netedit is in other esxi  but the same vlan
    Knowing that I can from Switches to netedit
    I reinstall srv in the same esxi with same network vm and the problem was solved
    MohammedEL MACHTI
