Dear,
Is there any difference as the installation of antennas in Aruba OC51505 installation mode or Oc51505H or OC24005 and OC24006-H in AP 175p (without cable) directly to the AP.I know what differentiates the principle is the polarization, one vertical and one horizontal, but it changes during implementation?
Thanks.
Not sure I follow 100%, but you can put the V on top and H on the bottom, or vide versa, it should work fine either way. I prefer to put the V-pol antennas on the CH0 connectors, but technically it shouldn't matter.
OK Thanks Jerrod.
