Aruba OS 105: Current version 6.4.2.0-4.1.1.1_46936:
  • 1.  Aruba OS 105: Current version 6.4.2.0-4.1.1.1_46936:
    Posted Apr 30, 2015 10:08 AM
    When click check for New Version get message: Receive no response from server. Have retried several times with same response.
  • 2.  RE: Aruba OS 105: Current version 6.4.2.0-4.1.1.1_46936:
    Posted Apr 30, 2015 11:42 AM
    Does your IAP have internet access?
    the 4.1 code is considered early availability therefore the cloud may not detect a newer version for you.
    Try pinging from the CLI
    images.arubanetworks.com and device.arubanetworks.com
  • 3.  RE: Aruba OS 105: Current version 6.4.2.0-4.1.1.1_46936:
    Posted Apr 30, 2015 12:17 PM
    Yes, I am able to access the Internet and successfully pinged the urls you
    suggested. I suspect you are correct that there is not a newer version.
    Thank you,
    *​SJS1*
  • 4.  RE: Aruba OS 105: Current version 6.4.2.0-4.1.1.1_46936:
    Posted Apr 30, 2015 12:35 PM
    There are newer versions its just that they are not available from the cloud.
    If you have access to the support site, you can download the latest 4.1.x release.
  • 5.  RE: Aruba OS 105: Current version 6.4.2.0-4.1.1.1_46936:
    Posted Apr 30, 2015 12:59 PM
    Thank you. Working on getting access now.
    *​SJS1*
