Network Management
Aruba OS 6.5.4.3 cant send web reputation and web categories
  • 1.  Aruba OS 6.5.4.3 cant send web reputation and web categories
    Posted Nov 20, 2017 02:38 PM
    Dear All,
    i have controller 7010 with AOS 6.5.4.3 and airwave 8.2.3,
    my question is, why controller cant send like log to airwave like web rep and web categories eventhough i'm already config the controller and airwave to syncronize like amon and everything, but at controller there is no feature apprf, just traffic analyze
    kindly need your help
  • 2.  RE: Aruba OS 6.5.4.3 cant send web reputation and web categories
    Posted Nov 20, 2017 05:03 PM
    In 6.5.x.x and above, Web Content Classification requires a license:
    http://www.arubanetworks.com/assets/ds/DS_WebCC.pdf
    It was never enforced before ArubaOS 6.5.x.x.  If you had the license installed, this is what it would look like in the AppRF Tab on the controller:
  • 3.  RE: Aruba OS 6.5.4.3 cant send web reputation and web categories
    Posted Nov 20, 2017 10:50 PM
    Dear Cjoseph,
    i'm already input license web cc,
    but at airwave still not showing web reputation and web category,
    is there any configuration i should put again ?
    attached the screenshoot
  • 4.  RE: Aruba OS 6.5.4.3 cant send web reputation and web categories
    Posted Nov 20, 2017 10:56 PM
    You don't have an AppRF tab on your controlller.  Check the license.
  • 5.  RE: Aruba OS 6.5.4.3 cant send web reputation and web categories
    Posted Nov 20, 2017 11:01 PM
    Dear Cjoseph,
    i'm already generate license web cc as your recommendation attached pdf
    what part number for lic apprf ? is there any trial for this license ?
  • 6.  RE: Aruba OS 6.5.4.3 cant send web reputation and web categories
    Posted Nov 21, 2017 02:56 AM
    Hi, four things:
    1) The WebCC subscription is a per AP subscription, so you should have 15 as the quantity of WebCC (screenshot shows 1)
    2) Make sure that under Advanced Services->Stateful Firewall, the option Enable Web Content Classification is enabled:
    3) Make sure you have DNS enabled on the controller, and that the controller can reach aruba.brightcloud.com for the lookups: http://community.arubanetworks.com/t5/Wireless-Access/how-use-port-tcp-udp-WebCC-url-lookup/m-p/272883/highlight/true#M62811
    To check from the command-line:
    (Aruba7005-1) #show web-cc status
    Web Content Classification Status
    Service                               Status
    Web Content Classification enabled :  Yes
    DNS/Name Server configured :          Yes
    URL Cloud lookup server reachable :   Yes
    Cloud lookup/update available :       Yes
    4) Make sure that you see in the controller you see data in the AppRF-Web Content tab:
    Only if you see the Web Content in the controller, you can see it afterward in AirWave.
