Thanks, but I'm still having an issue that the APs won't grab a license.
VMC:
AP Database
Name Group AP Type IP Address Status Flags Switch IP Standby IP
LabAP default 205 10.129.32.170 Up 5m:14s 2IL 10.129.34.97 0.0.0.0
(VMC) #show license-usage ap
AP Licenses
Type Number
AP Licenses 32
RF Protect Licenses 0
PEF Licenses 32
MM Licenses 32
MC-VA Licenses 32
MC-VA country US(Ter: US)
Controller License True
Overall AP License Limit 0
AP Usage
Type Count
Active CAPs 0
Active RAPs 0
Remote-node APs 0
Tunneled nodes 0
Total APs 0
Remaining AP Capacity
Type Number
CAPs 0
RAPs 0
(-VMC) #show license
License Table
Key Installed Expires(Grace period expiry) Flags Service Type
xxxxxxx 2017-06-19 10:21:26[1] 2017-07-19 10:21:26 ED MC-VA-RW: 1000
License Entries: 1
Flags: A - auto-generated; E - enabled; S - Subscription; R - reboot/activation key required to activate; D - Not enabled on license client
Note: Time under 'Installed' for Subscription licenses is the license generation time.
Mobility Master:
(ArubaMM) ^[mynode] #show license-usage ap
AP Licenses
Type Number
AP Licenses 499
PEF Licenses 499
MM Licenses 50
MC-VA Licenses 499
AP Usage [Note: THIS CONTROLLER DOES NOT TERMINATE ANY AP]
Type Count
Active CAPs 0
Active RAPs 0
Remote-node APs 0
Tunneled nodes 0
Total APs 0
Type Number
CAPs 0
RAPs 0
License Table
xxxxx 2017-06-19 09:48:24[1] 2017-07-19 09:48:24 E MM-VA: 50
xxxxx 2017-06-19 10:37:51[1] 2017-07-19 10:37:51 E Access Points: 2048
xxxxx 2017-06-19 10:38:50[1] 2017-07-19 10:38:50 E Next Generation Policy Enforcement Firewall Module: 2048
xxxxx 2017-06-19 11:48:46[1] 2017-07-19 11:48:46 E MC-VA-US: 1000
License Entries: 4
Am I missing a license? Every time I try to install a license on my VMC, I get an error "Adding centralized license is disallowed on local controller. Please install on Master controller."
I only have 1 controller and 1 mobility master.
