Original Message:
Sent: May 22, 2024 03:08 AM
Subject: Aruba OS 8.10.0.11 can't see WLAN config in Mobility Conductor and Mobility Controller
Update:
MS Edge type F12, accept developer tools, right click on refresh, select clear cache and force refresh
Now it works for me.
Original Message:
Sent: May 22, 2024 02:04 AM
Hello together,
does the update to 8.10.0.12 help for anyone?
I updated the conductor and one of my clusters, but the problem still exists, even on the updated cluster.
Thanks and kind regards
Robert
Original Message:
Sent: May 16, 2024 12:10 PM
If the APs connect back to the controller then they will pull whatever version the controller is running, if there is a mismatch between AP and controller.
There's nothing about the 8.10.0.11 (or 8.10.0.12) upgrade that should have caused the APs to stop communicating with the controller beyond the initial upgrade and reboot process itself.
Carson Hulcher, ACEX#110
Original Message:
Sent: May 16, 2024 12:03 PM
I suppose my question is, if I move to 8.10.0.12, with the AP's offline, will they get updated? Trying to avoid the need to visit 124 AP's.
Original Message:
Sent: May 16, 2024 11:56 AM
do you updated to 8.10.0.11?
Because 8.10.0.12 was released, the bug was fixed this week..
Best regards, mom
Original Message:
Sent: May 16, 2024
Subject: RE: Aruba OS 8.10.0.11 can't see WLAN config in Mobility Conductor and Mobility Controller
We updated last night, and experienced the same issue. I have a TAC case opened and learned that there was in fact a bug. Another issue we have is that several AP's that are DOWN (125) and are unreachable by IP, I can't ping them. Do you know if the software update might have changed the config on the AP? We use static IP assignment.
Thank you
Original Message:
Sent: May 15, 2024 12:12 PM
AOS 8.10.0.12 is released today, available soon at https://networkingsupport.hpe.com/, and should fix the display bug.
Original Message:
Sent: May 06, 2024 05:46 AM
hi there
i upgrade Mobility Conductor and Mobility Controller to version 8.10.0.11, after upgrade success i can't see WLAN config. Is this bug in version 8.10.0.11 ? I need upgrade to version 8.10.0.11 because from version 8.10.0.10 there is exploit
