Wired Intelligent Edge
Aruba OS-CX 10.02 and unsupported tranceivers
  • 1.  Aruba OS-CX 10.02 and unsupported tranceivers
    Posted Feb 15, 2019 07:43 AM
    Hi everyone,
    We are installing new VSX stack based on Aruba 8230 with  TL.10.02.0001 and having issues with unsupported tranceivers which is annoying. For example we have some SPF+ DAC cable from Lenovo and try to connect it to anothe HP 5500 chasis. On HP side the tranceiver is recognized and there is warning but it works. However on the 8320 it's not even recognized as anything.
    Is there any way that we enable unsupported tranceivers on 8320 like on 3810 for example or we need to stick only to the supported devices? It's very annoying since we have also some fiber SPFs which are not working on the 8320.
  • 2.  RE: Aruba OS-CX 10.02 and unsupported tranceivers
    Posted Feb 15, 2019 07:49 AM
    There is no command to enable unsupported transceivers on ArubaOS-CX (8400/8320/8325).
  • 3.  RE: Aruba OS-CX 10.02 and unsupported tranceivers
    Posted Feb 15, 2019 07:53 AM
    Ok so basically we have to stick to the supported ones and buy new DAC cables/tranceivers, right?
  • 4.  RE: Aruba OS-CX 10.02 and unsupported tranceivers
    Posted Feb 15, 2019 07:56 AM
    Correct, only the official supported DACs or transceivers will work.
  • 5.  RE: Aruba OS-CX 10.02 and unsupported tranceivers
    MVP GURU
    Posted Feb 15, 2019 09:34 AM
    As reference use this ArubaOS-Switch and ArubaOS-CX Transceiver Guide (January 2019) to understand all supported transceivers.
