Aruba OS for 7200 controllers
  • 1.  Aruba OS for 7200 controllers
    Posted Sep 09, 2013 07:13 AM
    My network is made up 2 6000 controllers with M3 and other 2 6000 controllers with SC1, I'm going to replace 2 controllers (SC1) for 2 new 7200 controllers, the question is:
    What's the minimum Aruba OS supported by 7200 controllers?.
    I'm currently running OS 5.0.3.0, so what path should I follow to upgrade??
    Thank you
  • 2.  RE: Aruba OS for 7200 controllers
    Posted Sep 09, 2013 07:38 AM
    The min is 6.2 but I would recommend our latest 6.3 code.
  • 3.  RE: Aruba OS for 7200 controllers
    Posted Sep 09, 2013 07:48 AM
    You'll want to upgrade to 5.0.4.12 then to 6.2.
    6.2 is supported on 72x0, M3, 3x00, and the 600 series controllers.
  • 4.  RE: Aruba OS for 7200 controllers
    MVP
    Posted Sep 09, 2013 09:45 AM
    The SC1 do not support 6.X code. That likely prevents them from upgrading their existing infrastructure to 6.X.
  • 5.  RE: Aruba OS for 7200 controllers
    Posted Sep 10, 2013 02:45 AM
    Yes, you are right.
    Due to it, we are planning upgrade to 2 7200 ( replacement of 6000 with SC1), but the problem is that 7200 come with Aruba OS 6.x (minimum) and our network run AOS 5.0.3.
    So, the upgrade should be
    1.- upgrade our network to 5.0.4.12.
    2.- upgrade to 6.x, taking out our SC1 controllers.
    3.- install the new 7200 with 6.x
