aruba os WLC upgrade 6.5.1.5
  • 1.  aruba os WLC upgrade 6.5.1.5
    Posted Nov 13, 2017 12:19 PM
    Hi all, im trying to upgrade a WLC to version 6.5.1.5.
    however when looking on the download os section of the aruba support page, it has two entries:-
    ArubaOS_70xx_6.5.1.5
    ArubaOS_72xx_6.5.1.5
    Does anyone know the difference between the two, and if there are any issues with compatibility with AP 105s. I have looked through the release notes for this version but it isnt really clear on these two points.
    thanks for any help given.
  • 2.  RE: aruba os WLC upgrade 6.5.1.5
    Posted Nov 13, 2017 12:46 PM
    Which model WLC do you have?
  • 3.  RE: aruba os WLC upgrade 6.5.1.5
    Posted Nov 13, 2017 12:48 PM
    Hi Colin, i have a Aruba 7210.
    thanks
  • 4.  RE: aruba os WLC upgrade 6.5.1.5
    Posted Nov 13, 2017 12:57 PM
    Then you need ArubaOS_72xx_6.5.1.5
    The AP-105 is still supported in 6.5.x
  • 5.  RE: aruba os WLC upgrade 6.5.1.5
    Posted Nov 13, 2017 01:07 PM
    Great, thanks for the response, I'll make sure to use that one.
    Can you please tell me (or point me at somw documentation) that shows the difference between the two.
    In case i come across this issue in the future.
    Thanks again
  • 6.  RE: aruba os WLC upgrade 6.5.1.5
    Posted Nov 13, 2017 02:34 PM
    If you downloaded it from the downloads folder, it says what version of code goes to what type of controller.Screenshot 2017-11-13 at 13.32.20.png
  • 7.  RE: aruba os WLC upgrade 6.5.1.5
    Posted Nov 14, 2017 06:14 AM
    Thanks again colin, this was very helpful, still finding my feet with this technology, much appreciated.
    kudos given.
