Aruba RAP contact to public IP VMC AOS8.3 problem need help
This thread has been viewed 23 times
  • 1.  Aruba RAP contact to public IP VMC AOS8.3 problem need help
    Posted Jun 27, 2018 11:30 PM
    Please take a look above diagram,and we explain the ip add as follow:
    1. 47.104.193.111 is the public ip of our AOS8.3 VMC,there are 1:1 dst-nat to the VMC vlan1 ip 172.31.4.51/20 default gateway is 172.31.15.253/20
    In fact there are only one ip in our VMC
    (AOS83) [mynode] #show ip interface bri
    Interface IP Address / IP Netmask Admin Protocol VRRP-IP
    vlan 1 172.31.4.51 / 255.255.240.0 up up
    loopback 172.31.4.52 / 255.255.255.255 up up
    (AOS83) [mynode] #show ip route
    Codes: C - connected, O - OSPF, R - RIP, S - static
    M - mgmt, U - route usable, * - candidate default, V - RAPNG VPN/Branch
    I - Ike-overlay, N - not redistributed
    Gateway of last resort is Imported from DHCP to network 0.0.0.0 at cost 10
    Gateway of last resort is Imported from CELL to network 0.0.0.0 at cost 10
    Gateway of last resort is Imported from PPPOE to network 0.0.0.0 at cost 10
    Gateway of last resort is 172.31.15.253 to network 0.0.0.0 at cost 1
    S* 0.0.0.0/0 [0/1] via 172.31.15.253*
    C 172.31.0.0/20 is directly connected, VLAN1
    mgmt unassigned / unassigned up up
    2.our RAP local ip is 172.16.5.236(dhcp from our home router), our home router get the public from isp is 111.37.21.67 (we do not get this public directly, it is also be NAT from our isp),So we  open NAT-T in our VMC
    3.We Contact our RAP by pre-shared key to our VMC
    apboot> printenv
    bootargs=
    bootdelay=2
    baudrate=9600
    autoload=n
    boardname=Dalmore
    servername=aruba-master
    bootcmd=boot ap
    autostart=yes
    bootfile=mips32.ari
    ethaddr=24:de:c6:cb:79:40
    name=24:de:c6:cb:79:40
    group=ArubaRap
    ikepsk=7C79E8210EB92264F7728ECD09EC5926055C5C527FA28CB91CCB63B3A2ED4C26
    papuser=arubarap
    pappasswd=90B311DE7AFCEBA589BA188EA766B30F14A695708421EBA8DD3E811C582C4B1A
    a_antenna=0
    g_antenna=0
    usb_type=0
    mesh_role=0
    installation=0
    remote_ap=1
    priority_ethernet=0
    priority_cellular=0
    cellular_nw_preference=1
    mesh_sae=0
    ip6prefix=64
    usb_power_mode=0
    ap_power_mode=0
    ethact=eth0
    start_type=cold_start
    master=47.104.193.111
    num_total_bootstrap=8
    num_reboot=8
    stdin=serial
    stdout=serial
    stderr=serial
    QQ截图20180628112358.png4.we boot our RAP,and we found it get the tunnl up and get the ip address
    Kernel IP routing table
    Destination Gateway Genmask Flags Metric Ref Use Iface
    47.104.193.111 192.168.100.222 255.255.255.255 UGH -3 0 0 br0
    172.31.4.52 0.0.0.0 255.255.255.255 UH 0 0 0 tun0
    192.168.100.0 0.0.0.0 255.255.255.0 U 0 0 0 br0
    192.168.11.0 0.0.0.0 255.255.255.0 U 0 0 0 br0
    0.0.0.0 0.0.0.0 0.0.0.0 U 0 0 0 tun0
    0.0.0.0 192.168.100.222 0.0.0.0 UG -3 0 0 br0
    We can not ping 172.31.4.52 , time out. anybody know the reason ?
  • 2.  RE: Aruba RAP contact to public IP VMC AOS8.3 problem need help
    Posted Jun 27, 2018 11:41 PM
    The followed information we get from our rap
    ~ # route -n
    ~ # ping 192.168.11.1 (This ip we are not sure where is it ?,but we know it dhcp from VMC)
    PING 192.168.11.1 (192.168.11.1): 56 data bytes
    64 bytes from 192.168.11.1: icmp_seq=0 ttl=64 time=0.1 ms
    64 bytes from 192.168.11.1: icmp_seq=1 ttl=64 time=0.1 ms
    --- 192.168.11.1 ping statistics ---
    2 packets transmitted, 2 packets received, 0% packet loss
    round-trip min/avg/max = 0.1/0.1/0.1 ms
    ~ # ping 47.104.193.111
    PING 47.104.193.111 (47.104.193.111): 56 data bytes
    64 bytes from 47.104.193.111: icmp_seq=0 ttl=50 time=13.2 ms
    64 bytes from 47.104.193.111: icmp_seq=1 ttl=50 time=13.1 ms
    --- 47.104.193.111 ping statistics ---
    round-trip min/avg/max = 13.1/13.1/13.2 ms
    ~ # ping 172.31.4.52 This ip is VMC Controller-IP from loopback
    PING 172.31.4.52 (172.31.4.52): 56 data bytes
    --- 172.31.4.52 ping statistics ---
    11 packets transmitted, 0 packets received, 100% packet loss
    The followed information we get from our Public VMC
    (AOS83) [mynode] #show ap system-profile default
    AP system profile "default"
    Parameter Value
    RF Band g
    Recovery Mode auto
    RF Band for AM mode scanning all
    Native VLAN ID 1
    Tunnel Heartbeat Interval 1
    Session ACL ap-uplink-acl
    Corporate DNS Domain N/A
    SNMP sysContact N/A
    LED operating mode (11n/11ac APs only) normal
    LED override Disabled
    Driver log level warnings
    Console log level emergencies
    SAP MTU N/A
    RAP MTU 1200 bytes
    LMS IP N/A
    Backup LMS IP N/A
    LMS IPv6 N/A
    Backup LMS IPv6 N/A
    LMS Preemption Disabled
    LMS Hold-down Period 600 sec
    LMS ping interval 20
    Remote-AP DHCP Server VLAN N/A
    Remote-AP DHCP Server Id 192.168.11.1
    Remote-AP DHCP Default Router 192.168.11.1
    Remote-AP DHCP DNS Server N/A
    Remote-AP DHCP Pool Start 192.168.11.2
    Remote-AP DHCP Pool End 192.168.11.254
    Remote-AP DHCP Pool Netmask 255.255.255.0
    Remote-AP DHCP Lease Time 0 days
    Remote-AP uplink total bandwidth 0 kbps
    Remote-AP bw reservation 1 N/A
    Remote-AP bw reservation 2 N/A
    Remote-AP bw reservation 3 N/A
    Remote-AP Local Network Access Disabled
    Flex Radio Mode 2.4GHz-and-5GHz
    Dual 5GHz Mode Automatic
    IPM activation Disabled
    IPM power reduction steps with priorities N/A
    IPM Steps delete all No
    Bootstrap threshold 8
  • 3.  RE: Aruba RAP contact to public IP VMC AOS8.3 problem need help
    Posted Jun 27, 2018 11:44 PM
    We also have one PC in the same network with our RAP,
    If we do not power RAP, we can access the VMC public IP 47.104.193.111 bye WEB and SSH (1:1 nat to 172.31.4.51)
    but If we power up our RAP, and boot finished, we found we still can ping 47.104.193.111 OK, but we CAN NOT access by WEB and SSH!!!
    anybody can see all of the information and help us ?
  • 4.  RE: Aruba RAP contact to public IP VMC AOS8.3 problem need help
    Posted Jun 28, 2018 12:08 AM
    If you have any question about the aboved diagram, please just ask us here, we will explain to you
  • 5.  RE: Aruba RAP contact to public IP VMC AOS8.3 problem need help
    Posted Jun 29, 2018 05:08 AM
    anybody here can help me ? thanks
  • 6.  RE: Aruba RAP contact to public IP VMC AOS8.3 problem need help
    Posted Jun 29, 2018 06:48 AM
    Have you tried opening a TAC case?
  • 7.  RE: Aruba RAP contact to public IP VMC AOS8.3 problem need help
    Posted Jun 29, 2018 06:21 PM
    No. I do not know how to open Case
    I get one HPE friends  help me to find the reason now.
