Aruba RAP in Rc2I mode
  • 1.  Aruba RAP in Rc2I mode
    Posted Oct 23, 2018 04:57 PM
    I converted IAP 315 to RAP. Now it shows flag as Rc2I. I want this RAP to plug into home network so I can connect back to work network and broadcast work SSIDs. Please help!
  • 2.  RE: Aruba RAP in Rc2I mode
    Posted Oct 24, 2018 02:35 AM
    Which AP-group did you provision this RAP in?
    Does this AP-group have any VAPs active?
    Does the AP stay up permanently with the Rc2I-flags, or does it rebootstrap?
  • 3.  RE: Aruba RAP in Rc2I mode
    MVP EXPERT
    Posted Oct 24, 2018 04:45 AM
    Can you please confirm the last flag you are seeing, is this either "l" or "I".
     L = Unlicensed : Check you have enough licenses available for the RAP. (#show license limits)
    I = Inactive : As what @dojjan said, check you have the necessary VLAN's in place on the controller which is terminating the RAP. On the controller where the RAP terminates, run the command #show profile-errors to see if there is any errors with your configuration.
