Aruba Replacement
  • 1.  Aruba Replacement
    Posted Jan 20, 2015 08:29 AM
    Dear All ;
     We have Aruba 2400 Controller and about 125 AP-61 in the network. We Plan to replace them with Aruba 3600 controlelr and AP-93. can Aruba support the replacement old products with new under replacement program or discount ?
    Thank you
    #3600
  • 2.  RE: Aruba Replacement
    Posted Jan 20, 2015 09:03 AM
    Ap-93 are end-of-sale, the direct equivalent would be a ap-103. .
    Aruba will not support the AP-93 after a specific date specified below.
    http://www.arubanetworks.com/support-services/end-of-life-products/
    I suggest you speak to your channel manager or Aruba SE to get you what you need for your design.
    You may want to use a 7210 with ap-103s based on your deployment
    #7210
