Wired Intelligent Edge
Aruba S1500 MAS - Flash Device Not Ready Error on Boot and CPBoot CLI
  • 1.  Aruba S1500 MAS - Flash Device Not Ready Error on Boot and CPBoot CLI
    Posted Jul 02, 2018 06:31 PM
    Hi All,
    I'm putting together a wireless lab and having some problems with the MAS switches.  I've configured and built AP's, a 7010 controller, and other devices, but the S1500 switches are giving me problems.
    These two switches I have received from the same Ebay vendor are having the same problem.  So I need to figure out if I can fix the problems or return the switches.
    Is there any removable storage on these devices or something that could be missing after a factory restore?  I had one open and there doesn't seem to be a place for removable storage.
    Here is the error I get on boot and the error I get when trying to do an upgrade in CPboot mode.
    CPBoot 1.0.46.0 (build 43231)
    Built: 2014-04-15 at 10:35:41
    1024MB DRAM init, XLS CPU, 64bit channel pair mode
    DDR2 DRAM running at 533Mhz
    DRAM:  Total = (0x40000000) 1024 MB
    POST:  Memory test: Physical 0x00000000 - 0x10000000 - quick test
          Memory test: Physical 0x10000000 - 0x40000000 - quick test
          PASS
    CPU:   XLS208, rev. A1 Clock: 750MHz
    CPLD:  rev: 1.8 (0x1.8)
    SMP:   All 8 cpus successfully started
    Board: S1500-12P
    PCIE:  RCx4 mode
    Inven: primary inventory is OK
    POST2: System Voltages
          PASS
    PCIE0: Link Up. (PhyUp=1 DatLnkUp=1 PwrMode=0 LtssmState=17)
          Aruba DPE (PCIE-DevId 0xDF7C)
          BAR1(64M) @ 0xC0000000 (phys 0x60000000)
          BAR0( 1M) @ 0xC4000000 (phys 0x64000000)
    PoE:   OK - Ports remain disabled
    Net:   xls_gmac0 [PRIME], xls_gmac1, xls_gmac2, xls_gmac3
    Boot:  Primary bootflash partition
    Reboot code: 8:b3:22:29:27
    Hit any key to stop autoboot:  0
    booting system partition 0:0
    USB:   USB 2.0 started, EHCI 1.00scanning bus for devices... 2 USB Device(s) found
          scanning bus for storage devices... Device NOT ready
      Request Sense returned 02 3A 00
    max USB Storage Device reached: 1 stopping
    1 Storage Device(s) found
    Device NOT ready
    0 blocks read: ERROR
    0: Partition not created
    Device NOT ready
    Image not present
    booting system partition 0:1
    Device NOT ready
    1: Partition not created
    Device NOT ready
    Image not present
    booting system partition 0:2
    Device NOT ready
    2: Partition not created
    Device NOT ready
    Image not present
    booting system partition 1:0
    Image not present
    booting system partition 1:1
    Image not present
    booting system partition 1:2
    Image not present
    cpboot> pfe mgmt
    UPLINK_PRESENT_L  = 0
    UPLINK_POWER_GOOD = 0
    CPLD settings: Bobcats out of reset (POE enable not changed)
    CPLD settings: Phy out of reset (POE reset not changed)
    Phy Led Blink
    pcie0stat = 17 (DPE near power supply )
    pcie1stat =  0 (DPE near Uplink       )
    pcie2stat =  0 (device on Uplink board)
    CPLD Board Id = 14
    Autodetected Cointreau12 based on PCIE link status
    List of registered PCI devices
    Vendor 11AB Device DF7C on bus 1
    Bobcat autoinit
    pci read 0xc0000050 [vendor_id]...= 000011AB (expecting 0x00011AB)
    Bobcat 0 speed 222245640
    Detecting uplink:
    MarvellXphy   = 0
    MarvellCub    = 0
    MarvellBobcat = 0
    MarvellSolaia = 0
    PCI3_FPGA     = 0
    Uplink=Direct SFP
    Start bobcat(s) configuration
    Configure Cpu GMAC1 PHY
    Configure Cpu GMAC2 PHY
    End bobcat(s) configure
    configured the front panel port 0 as managment port
    cpboot> saveenv
    Saving Environment to Flash...
    Erasing ##
    Erased 2 sectors
    Writing ################
    cpboot> printenv
    bootargs=quiet
    bootcmd=bootf
    bootdelay=5
    baudrate=9600
    loadaddr=0x87000000
    bootfile=vmlinux.strip
    psb_os_cpu_mask=0
    userapp_cpu_map=0x0f
    eth6addr=00:0b:86:99:47:42
    eth7addr=00:0b:86:99:46:42
    ethprime=xls_gmac0
    ipaddr=192.168.2.133
    netmask=255.255.255.0
    serverip=192.168.2.12
    gatewayip=192.168.2.254
    boardname=cointreau
    mgmt_port=0
    netretry=no
    ethaddr=00:0b:86:92:41:b8
    eth1addr=00:0b:86:92:41:b9
    eth2addr=00:0b:86:92:41:ba
    eth3addr=00:0b:86:92:41:bb
    eth4addr=00:0b:86:92:41:bc
    eth5addr=00:0b:86:92:41:bd
    stdin=serial
    stdout=serial
    stderr=serial
    ethact=xls_gmac0
    Environment size: 562/131068 bytes
    cpboot> ping 192.168.2.12
    Using xls_gmac0 device
    host 192.168.2.12 is alive
    cpboot> upgrade 0:0 ArubaOS_MAS_7.4.1.9_62608
    0: Device not present
  • 2.  RE: Aruba S1500 MAS - Flash Device Not Ready Error on Boot and CPBoot CLI
    Posted Aug 20, 2018 03:56 PM
    Try upgrading partition 0 through cpboot, it looks like there is no (valid) images in the partitions.
    cpboot> setenv serverip <TFTP server IP here>
    cpboot> upgrade 0/1 ArubaOS_MAS_7.4.1.9_62608
    cpboot> saveenv
    cpboot> boot
    Edit:
    Nevermind, I see you already tried that.
