The NAT processing will run on the switch CPU, which is not really powerful. I can't find exact numbers, but it remember there was a limit on NAT and IPSec throughput on the S1500. The numbers in the datasheet are for switching performance only. 200Mbps of NAT throughput does not sound strange to me.
Original Message:
Sent: Oct 01, 2022 03:46 PM
Subject: Aruba s1500 NAT issue
Hello
I have an old aruba s1500 of 12p at home and everything works fine
My s1500 has some vlans and it has some interface vlans and its the one routing
I also got 2 aruba instant APs
This is the issue i have
When i do a speed test and im natting the performance is really bad. I got 500mb and i get like 200mb out of it
If im not natting i get my 500m
I used the same port
i just find this really odd
Any ideas what it could be?
