Aruba S2500-24P not powering on Wireless AP via PoE
  • 1.  Aruba S2500-24P not powering on Wireless AP via PoE
    Posted Sep 19, 2020 01:22 AM
    Unfortunately I'm not getting my Unifi AP Pro to power up via PoE. Originally I thought it was the AP to blame, so I purchased a second to try, but it has the same behavior of the first - no indication of any power when plugged in via ethernet only. Powers up if I use the PoE injector.
    Nothing obviously bad in the logs on the S2500. The web GUI shows PoE is enabled on the ports I'm plugging in. I updated the port profiles to only use PoE on 4 ports in case there was some power limitation issues. I also ran some diagnostic commands and nothing is looking out of the ordinary from what I can tell (output included at end of post).
    The only lead I have is when I switch the LED mode to PoE the LEDs on the ports that have PoE enabled are blinking. According to the manual (https://support.hpe.com/hpesc/public/docDisplay?docLocale=en_US&docId=c05315600) that means " Power enabled, but power denied due to unavailability." Searching the internet for that hasn't brought up anything more detailed about that state though, so I don't know if that indicates something is actually wrong or it just means the switch doesn't see a device that is available to power on that port.
    Any help or ideas would be greatly appreciated! I'm unsure if I should return the hardware to the seller at this point or if I am missing something and just need to change a setting somewhere. I did a factory reset and installed the latest firmware as soon as I got the switch. I also booted into the other partition with an older firmware version to see if that helped, but no difference.
    (ArubaS2500-24P) #show inventory
    Show Inventory
    System Card Slot              : 0
    SC Serial #                   : xxx (Date: 08/28/14)
    SC Model Name                 : ArubaS2500-24P
    Mgmt Port HW MAC Addr         : xxx
    HW MAC Addr                   : xxx
    CPLD Version                  : Rev: 2.8 (0x2.8)
    PoE Firmware Version          : 0.0.0 (Build: 0)
    CPU Assembly #                : 2010152C (Rev: 08.00)
    CPU Serial #                  : xxx (Date: 08/28/14)
    Power Supply                  : Present (580W)
                                  : 12V System Voltage Ok
                                  : 56V PoE Voltage Ok
    Power Supply Serial #         : xxx (Date: 08/01/14)
    Power Supply Model No         : 2510064
    Power Supply Vendor Model No  : IPSN-580APA1 (Rev: 48.48)
    Console Card Assembly #       : 2010111C (Rev: 01.00)
    Console Card Serial #         : xxx (Date: 08/28/14)
    PoE Card Assembly #           : 2010108C (Rev: 01.00)
    PoE Card Serial #             : xxx (Date: 08/28/14)
    System Temperature            : CPU Temp                : 47  C
                                  : DPE Temp                : 47  C
                                  : DDR Temp                : 38  C
                                  : PSU Temp0               : 38  C
                                  : PSU Temp1               : 39  C
                                  : Exhaust Temp            : 40  C
                                  : Mid Temp                : 42  C
                                  : Ambient Temp            : 37  C
                                  : Console Card Temp       : 29  C
    System Voltages               : 3300mV Sense            : 3360.0 mV
                                  : 2500mV Sense            : 2464.0 mV
                                  : 1800mV Sense            : 1808.0 mV
                                  : 1000mV Sense            : 990.0 mV
                                  : 900mV CPU               : 920.0 mV
                                  : 1200mV Sense            : 1208.0 mV
                                  : 5000mV 5VDD             : 4998.0 mV
                                  : 5000mV 5VSB             : 4950.0 mV
    System Fan Tachometers        : Power Supply Fan 0      : 4655  RPM (Low Speed)
                                  : Power Supply Fan 1      : 4736  RPM (Low Speed)
                                  : FAN 0                   : 4804  RPM (Low Speed)
                                  : FAN 1                   : 4945  RPM (Low Speed)
    (ArubaS2500-24P) #show poe controller slot 0
    Linecard  Power Budget(W)  Power Consumption(W)  GuardBand(mW)  PoE Management  Cisco Compatibility  Config Delay(ms)
    0         400              0                     11000          Dynamic         Disabled             2000
    (ArubaS2500-24P) #show poe interface brief
    PoE Interface Brief
    Interface  Admin    Consumption(mW)  Port Priority  Port Status
    GE0/0/0    Enable   0                High           On
    GE0/0/1    Enable   0                High           On
    GE0/0/2    Enable   0                High           On
    GE0/0/3    Enable   0                High           On
    GE0/0/4    Disable  0                Low            On
    GE0/0/5    Disable  0                Low            On
    GE0/0/6    Disable  0                Low            On
    GE0/0/7    Disable  0                Low            On
    GE0/0/8    Disable  0                Low            On
    GE0/0/9    Disable  0                Low            On
    GE0/0/10   Disable  0                Low            On
    GE0/0/11   Disable  0                Low            On
    GE0/0/12   Disable  0                Low            On
    GE0/0/13   Disable  0                Low            On
    GE0/0/14   Disable  0                Low            On
    GE0/0/15   Disable  0                Low            On
    GE0/0/16   Disable  0                Low            On
    GE0/0/17   Disable  0                Low            On
    GE0/0/18   Disable  0                Low            On
    GE0/0/19   Disable  0                Low            On
    PoE Interface Brief
    GE0/0/20   Disable  0                Low            On
    GE0/0/21   Disable  0                Low            On
    GE0/0/22   Disable  0                Low            On
    GE0/0/23   Disable  0                Low            On
    (ArubaS2500-24P) #show poe interface gigabitethernet 0/0/3
    GE0/0/3: Administratively Enable, Port status: On
    Maximum power: 30000 mW, Power consumption: 0 mW
    Port voltage: 0 mV, Port current: 0 mA
    PD class: Class-0, Priority: High, PSE port status: On
    Thanks!
  • 2.  RE: Aruba S2500-24P not powering on Wireless AP via PoE
    Posted Sep 19, 2020 05:54 AM
    I have one of those and it should work fine.  I assume you have tried the other ports 0-2?
    What is your interface config?
    show run interface gigabit 0/0/3
  • 3.  RE: Aruba S2500-24P not powering on Wireless AP via PoE
    Posted Sep 19, 2020 10:57 AM
    Thanks for the reply. I have tried a number of ports, all with the same behavior. Here's the output from the command you suggested:
    (ArubaS2500-24P) #show run interface gigabitethernet 0/0/3
    interface-config gigabitethernet "0/0/3" detail
        interface-profile mstp-profile default
          point-to-point Disabled
          portfast Disabled trunk Disabled
          bpdufilter default Disabled
          bpdufilter unconditional Disabled
          rootguard Disabled
          loopguard Disabled
          bpduguard Disabled auto-recovery-time 0
        interface-profile pvst-port-profile default
          rootguard Disabled
          loopguard Disabled
        interface-profile lldp-profile lldp-factory-initial
          lldp transmit Enabled
          lldp receive Enabled
          lldp tlv-select port-description Enabled
          lldp tlv-select system-name Enabled
          lldp tlv-select system-description Enabled
          lldp tlv-select system-capabilities Enabled
          lldp tlv-select management-address Enabled
          lldp tlv-select port-vlan-id Enabled
          lldp tlv-select vlan-name Enabled
          lldp tlv-select aggregation-status Enabled
          lldp tlv-select mac-phy-config Enabled
          lldp tlv-select max-frame-size Enabled
          lldp tlv-select power-management Enabled
          lldp med-tlv-select network-policy Enabled
          lldp med-tlv-select power-management Enabled
          lldp transmit-interval 30
          lldp transmit-hold 4
          lldp fast-transmit-interval 1
          lldp fast-transmit-counter 4
          med enable Disabled
          proprietary-neighbor-discovery Disabled
        interface-profile poe-profile device-group-default
          enable Enabled
          poe-maxpower 30000
          poe-priority high
        interface-profile enet-link-profile default
          speed auto
          duplex auto
          autonegotiation Enabled
          flowcontrol off
        interface-profile switching-profile default
          switchport-mode access
          access-vlan 1
          native-vlan 1
          storm-control-broadcast Enabled
          storm-control-multicast Disabled
          storm-control-unknown-unicast Enabled
          storm-control-bandwidth 50
          trunk allowed vlan 1-4094
        mtu 1514
        qos trust aruba-device
        trusted port
        igmp-snooping mrouter-vlan 0
        mld-snooping mrouter-vlan 0
  • 4.  RE: Aruba S2500-24P not powering on Wireless AP via PoE
    Posted Sep 21, 2020 03:49 AM
    That is the same config I have which works fine.  Have you tried a different type of PoE capable device?
    All I can suggest at this point is to create a new PoE profile and apply that to the interface.
  • 5.  RE: Aruba S2500-24P not powering on Wireless AP via PoE
    Posted Sep 21, 2020 11:04 AM
    I have a PoE camera and an Aruba AP coming in the mail. If neither of those work it seems like I have a bad switch based on our configs matching.
    Thanks for your help giving me some more data points here.
  • 6.  RE: Aruba S2500-24P not powering on Wireless AP via PoE
    Posted Oct 04, 2020 01:16 PM
    I purchased a new switch and everything seems to be working fine with the PoE devices now. On this new piece of hardware when I put the LEDs in PoE mode they all stay unlit until I plug in a PoE device, at which point the status LED will light solid. So it looks like that original piece of hardware was faulty somehow, even though it wasn't showing as having issues in the console command output that I was seeing. Thanks for your help!
