Wired Intelligent Edge
Aruba s2500 access switch
  • 1.  Aruba s2500 access switch
    Posted Jun 12, 2016 02:36 PM
    Hi, can someone please help me the the mobility access s2500 switch. we currently bought a new access s2500 switch and I`m unable to access it via web gui. I followed the required steps of enabling web gui under maintanance and it does not help. The client ip address is on  the same subnet  as switch and when I try to login using the switch ip address it prompt me with the login page but when I enter admin and password it does not show anything.
  • 2.  RE: Aruba s2500 access switch
    Posted Jun 13, 2016 04:36 AM
    Hi Joshua,
    I have couple of questions:
    1. Did you try logging in using different browser ?
    2. Are you able to SSH in to the switch & login via putty,teraterm etc?
    In case you have console access to the switch, please attach the following output :
    1. Aruba# show port status
    2. Aruba# show user
  • 3.  RE: Aruba s2500 access switch
    Posted Jun 13, 2016 01:15 PM
    Thanks a lot. Upgrading the firmware solved the issue.
