Wired Intelligent Edge
Aruba S3500-24P * Safe to use a 350Watt PSU if no PoE usage?
  • 1.  Aruba S3500-24P * Safe to use a 350Watt PSU if no PoE usage?
    Posted Apr 13, 2018 05:05 PM
    First, I am new to this board, so I hope I posted in correct place.
    Long story but I am about to be gifted a used Aruba S3500-24P enterprise-grade Switch; including the 4-port 10GB Module.
    It would be for home use, mostly for its 10GB ports.
    The Aruba S3500-24P is a PoE Switch; and per the specs, normally comes with a 600watt or 1200watt PSU.
    ** I will not be using the PoE feature at all.
    I can obtain from someone else, a 350watt PSU; but do not know if safe to use.
    Question: if PoE is not being used on a Aruba S3500-24P, can a 350watt PSU be used?
    Thank you
  • 2.  RE: Aruba S3500-24P * Safe to use a 350Watt PSU if no PoE usage?
    Posted Jun 11, 2018 10:25 PM
    It does not appear to be supported in the documentation
    Thanks!
    -문서상으로는 지원하지 않는것으로 보입니다.power supplies modulespower supplies modules
