last person joined: 8 hours ago
Aruba Shared LIC
  • 1.  Aruba Shared LIC
    Posted Feb 13, 2014 02:39 PM
    If we have only  2 Controllers acting as Master/Backup Via VRRP   , License can be shared between them , is this Right ?
    For example , to terminate 100 AP on those Controllers  we need only 100 LIC ,  then In case of failure of mater   , the backup will take over & will have the full 100 LIC , Right ?
  • 2.  RE: Aruba Shared LIC
    Posted Feb 13, 2014 02:44 PM
    You cannot share licenses across controllers if you're not using AOS 6.3.
    < 6.3 you will need licenses for the controller terminating the APs and at least 1 AP and 1 PEf license on the master controller.
    If you're doing active/backup, then you need the same amount of licenses for both
    I believe with 6.3 License pooling is now available but I am not 100% sure how that works currently.
  • 3.  RE: Aruba Shared LIC
    Posted Feb 13, 2014 02:46 PM
    You should be able to shared Licenses across two controllers using Centralize Licensing .
    And like pmonardo said you need AOS 6.3 in order to accomplish this.
  • 4.  RE: Aruba Shared LIC
    Posted Feb 14, 2014 03:45 AM
    i understood , there is a limitation
    if Master controller is down , then backup rebooted , what will happend that backup will come up with no licenses ???
  • 5.  RE: Aruba Shared LIC
    Posted Feb 14, 2014 08:37 AM
    I have tested the Master going down scenario (the backup keeps the licenses for 30 days) but I have not tested the Master backup rebooting  while the Master still down (if will still hold the licenses)...that's a good and valid question....
  • 6.  RE: Aruba Shared LIC
    Posted Feb 25, 2014 05:26 AM
    and the answer seems to be the backup will then loose it licenses, something that makes this quite a dangerous feature.
    https://arubanetworkskb.secure.force.com/pkb/articles/FAQ/What-are-the-limitations-related-to-centralized-licensing-on-AOS-version-6-3-0-0
    not sure how to work around that at the moment, probably dont use a backup license server for now.
  • 7.  RE: Aruba Shared LIC
    That's correct.
