Developer
Aruba SSH/CLI Module
  • 1.  Aruba SSH/CLI Module
    Posted Sep 17, 2019 09:15 PM
    I am very new to Ansible and wondering if someone can look into this.
    I have installed the Python and Ansible as per the https://github.com/aruba/aruba-ansible-modules and videos "Aruba Bots Ansible Series 01 - 03". I can connect to the switch using the ansible modules. Please see the outupt below.
    python --version
    Python 2.7.16
    MacBook-Pro:arubaoss tarun$ ansible --version
    ansible 2.8.5
      config file = None
      configured module search path = ['/Users/tarun/.ansible/plugins/modules', '/usr/share/ansible/plugins/modules']
      ansible python module location = /usr/local/Cellar/ansible/2.8.5/libexec/lib/python3.7/site-packages/ansible
      executable location = /usr/local/bin/ansible
      python version = 3.7.4 (default, Sep  7 2019, 18:27:02) [Clang 10.0.1 (clang-1001.0.46.4)]
    MacBook-Pro:arubaoss tarun$ ansible-playbook system_attributes.yml -i switch_hosts.yml
    PLAY [switch1] ***********************************************************************************************************************************************************************
    TASK [Gathering Facts] ***************************************************************************************************************************************************************
    ok: [switch1]
    TASK [Update Switch System Attributes] ***********************************************************************************************************************************************
    changed: [switch1]
    PLAY RECAP ***************************************************************************************************************************************************************************
    switch1                    : ok=2    changed=1    unreachable=0    failed=0    skipped=0    rescued=0    ignored=0
    MacBook-Pro:arubaoss $
    However I am unable to use the SSH/CLI module as mentioned in the Aireheads community https://community.arubanetworks.com/t5/Developer-Community/How-to-install-use-CLI-modules-and-tasks-for-Switch-and-CX-in/td-p/534333/highlight/false
    $ansible-playbook cli-test.yml -i switch_hosts.yml
    ERROR! 'arubaos_switch_ssh_cli' is not a valid attribute for a Play
    The error appears to have been in '/home/tarun/aruba-ansible-modules/example_playbooks/arubaoss/cli-test.yml': line 1, column 3, but may
    be elsewhere in the file depending on the exact syntax problem.
    The offending line appears to be:
    - name: Check if upload is completed
      ^ here
    cat cli-test.yml
      arubaos_switch_ssh_cli:
        ip: 10.0.0.254
        user: netadmin
        password: netadmin
        # This will execute each command through the CLI and return the CLI Output
        show_command: ["show flash", "show version"]
      # The result will have the CLI Output
  • 2.  RE: Aruba SSH/CLI Module
    Posted Sep 18, 2019 12:48 PM
    Hi tarunagghi!
    Did you copy the library/ directory from the aruba-switch-ansible Github to the directory where your playbook cli_test.yml is? That should be step 2 of How to install/use CLI modules and tasks for Switch and CX in Ansible
    If you did, I would double check your indentation, some times that could throw an error, but I doubt that's the case here.
    Could you please re-run the playbook in verbose mode? Just append -vvvv to the end of the execution and reply with the results of the failure. So your execution command should look like this:
    ansible-playbook cli-test.yml -i switch_hosts.yml -vvvv
  • 3.  RE: Aruba SSH/CLI Module
    Posted Sep 18, 2019 07:57 PM
    Yes, I did copy the library and like you mentioned it was the indentation. I double-check and corrected my indentation and it's working now. I copied it to the ssh_working.yml
    I have attached the screenshot of the working indentation if someone has the same issue.
