Aruba Switch 2530 - Error Radius Coa - Invalid packet authenticator
  • 1.  Aruba Switch 2530 - Error Radius Coa - Invalid packet authenticator
    Posted Mar 06, 2019 05:56 AM
    I have a problem with the clearpass when I send a Radius Coa to the switch. It always gives me the same error:
    0000:00:25:52.77 RAD tRadiusR:DISCONNECT REQUEST id: 7 from 10.253.27.12
    DROPPED, Invalid packet authenticator.
    I have no problem in the validation user through 802.1x. It works well and in Clearpass validates, however when I send an RCoa the switch does not respond and makes a drop of the package.
    This is what I have configured in the switch:
    radius-server host 10.253.27.12 encrypted-key "encripted_key"
    radius-server host 10.253.27.12 dyn-authorization
    radius-server host 10.253.27.12 time-window 0
    SW(config)# sh radius
    Status and Counters - General RADIUS Information
    Deadtime (minutes) : 0
    Timeout (seconds) : 5
    Retransmit Attempts : 3
    Global Encryption Key :
    Dynamic Authorization UDP Port : 3799
    Source IP Selection : 192.168.116.13
    Source IPv6 Selection : Outgoing Interface
    Tracking : Disabled
    Auth Acct DM/ Time |
    Server IP Addr Port Port CoA Window |
    Encryption Key
    10.253.27.12 1812 1813 Yes 0 | encripted_key
                                        Disc      Disc    Disc    CoA     CoA   CoA
    IP Address                 Reqs   ACKs  NAKs   Reqs   ACKs   NAKs
    10.253.27.12                 12      0          0       3            0            0
    Can you help me?
    TY
  • 2.  RE: Aruba Switch 2530 - Error Radius Coa - Invalid packet authenticator
    Posted Mar 06, 2019 06:13 AM
    check whether below setting configured properly
    • RFC server IP configuration and shared secret
    • Port 3799 is allowed
    • What type of Radius CoA template you are using?
  • 3.  RE: Aruba Switch 2530 - Error Radius Coa - Invalid packet authenticator
    Posted Mar 11, 2019 08:09 AM
    • RFC server IP configuration and shared secret --> Yes, i can do 802.1x.
    • Port 3799 is allowed--> Yes, i receive in switch radius coa
    • What type of Radius CoA template you are using? --> [ArubaOS - Terminate Session]
    • Another one--> Same NTP Server
    I try with differents templates for Radius_Coa and ever i receive same error --> Invalid Packet Authenticator.
  • 4.  RE: Aruba Switch 2530 - Error Radius Coa - Invalid packet authenticator
    Posted Mar 11, 2019 09:39 AM
    Looks like you want a Disconnect, not a CoA. Use the [ArubaOS Switching – Terminate Session] profile.
  • 5.  RE: Aruba Switch 2530 - Error Radius Coa - Invalid packet authenticator
    Posted Mar 11, 2019 09:56 AM
    I want a radius coa, i use [ArubaOS switching - Terminate sesion] but i can use other, only want radius coa work fine.
    I try a diferents templates but none works
  • 6.  RE: Aruba Switch 2530 - Error Radius Coa - Invalid packet authenticator
    Posted Mar 11, 2019 09:59 AM
    If you’re trying to Disconnect the user, it’s a Disconnect, not a CoA. [ArubaOS Switching - Terminate Session] is the correct enforcement profile.
  • 7.  RE: Aruba Switch 2530 - Error Radius Coa - Invalid packet authenticator
    Posted Mar 13, 2019 04:19 AM
    Nice, i change profile, now i send Coa but i ve same error: invalid packet authenticator.
  • 8.  RE: Aruba Switch 2530 - Error Radius Coa - Invalid packet authenticator
    MVP EXPERT
    Posted Mar 06, 2019 06:20 AM
