Wired
Aruba Switch 6200F -L3 Switch
  • 1.  Aruba Switch 6200F -L3 Switch
    Posted Sep 26, 2022 12:25 PM
    Hi Team,
    Can i make /use the use 6200F Aruba switch Layer 3 switch like configuring static route and inter vlan (L3).Please confirm. Thanks
  • 2.  RE: Aruba Switch 6200F -L3 Switch
    Posted Sep 27, 2022 02:15 AM
    Hello
    You can use the Aruba Switch Feature Navigator
    https://feature-navigator.arubanetworks.com/
    Under Product Type select Fixed and under Plattform CX 6200.
    In the section L3 Features you can see that it supports ipv4 and ipv6 static routes.
    Further below you can see that it even supports OSPFv2 and v3.
    Another source of information is the datasheet.
    https://www.arubanetworks.com/assets/ds/DS_6200Series.pdf
    KEY FEATURES
    • Enterprise-class connectivity with support for ACLs,
    robust QoS and common protocols such as static
    and Access OSPF routing
    In the specification section you can find the information that the switches support 2048 ipv4 static routes and 1024 ipv6 static routes.
