Community Feedback
How is the community doing? Do you have any questions or feedback related for the Airheads Community team? This is the place to let us know.
Aruba Switch Change Management IP
  • 1.  Aruba Switch Change Management IP
    Posted Mar 27, 2024 09:17 AM
    I have two Aruba switches, and by mistake, I have configured same MGMT IPs on both the switches. Now I want to change MGMT Interface IP. How can I do that as I am able to login via Putty only. Switch Series : Aruba 2530.
    I have tried this commands = switch(config)# interface mgmt, but getting error like no mgmt port found.
    Please help me.
  • 2.  RE: Aruba Switch Change Management IP
    Posted Mar 27, 2024 11:12 AM
    What exact model switch are you configuring? most 2530's do not have dedicated mgmt interfaces
    Dedicated management interfaces can be configured under the "oobm" context.
    If my post was useful, please Accept Solution and Give Kudos.
    Zak Chalupka
    Principal Engineer - HPE Aruba
    ACDX | ACMP | ACSP | ACCP
    wifizak@hpe.com
    Ideas expressed here are solely my own and not necessarily that of HPE Aruba.
  • 3.  RE: Aruba Switch Change Management IP
    Posted Mar 28, 2024 03:11 AM
    Use "show ip" to list all ip addresses assigned to switch and then change management vlan interface address
    #  vlan <mgmt vlan>
    ip address <ip address> <mask>
    Best, Gorazd
    Gorazd Kikelj
    MVP Guru 2024
