Aruba Central
Aruba switch-cx 6000 default gateway
  • 1.  Aruba switch-cx 6000 default gateway
    Posted Jul 03, 2024 02:40 PM
    Hi all,
    I assigned an interface vlan ip on a switch as 10.254.32.3 (sw2) but I'm having difficulty adding a default gateway which is pingable "10.254.32.1". The AOS aruba switches that I was using in the past, used to be so simple because I could either add manually on the UI in central or through cli as"
    switch# ip default-gateway 10.254.32.1.
    It seems with cx you need to input a static route If I'm not mistaken such as
    switch# ip route 0.0.0.0/0 10.254.32.1
    Fyi, I'm able to ping the lan DG of 10.254.32.1 but because it's not on the switch, I'm not able to ping 8.8.8.8 or the web in general.
    At the moment I'm able to connect to switch2 through another that it's in cloud central "10.254.32.2 Sw-1". Since, Sw2 is locally connected to Sw1, I can directly ssh within cloud central.
