Has anyone gotten EST enrollment working from an Aruba Switch (e.g. 3810M) to ClearPass Onboard? I have the CA configured correctly as a registration authority (RA) and it is valid in Onboard. However, I am unable to get the switch to enroll due to SSL connection error. I have a ta-profile for the upstream intermediate CA that the RA is connected to loaded on the switch. I can't help but notice that the URL that ClearPass says to use for EST is using port 9 instead of 443. Thoughts? Just wondering what I am missing.
Shouldn't that be /9 instead of :9, is that a GUI display issue? ( I think the /9 is just the 9th Ca you have setup, it just increments each time)
If it was a port, it would be straight after your hostname, before the folder structure.
Good call on that. Yeah, that has to be a GUI bug.
Regardless, can't seem to get it to work. TAC call it is
I did notice that in Onboard you have the option for configuring the EST authentication for either shared secret or HTTP Basic/Digest. The switch does not seem to have shared secret as an option. Is there a place to configure the HTTP auth on the switch?
Nevermind. I found it. The user has to be an active guest account for HTTP auth.
