Aruba switch in Cisco network
  • 1.  Aruba switch in Cisco network
    Posted Nov 24, 2018 05:18 AM
    I just got my first Aruba switch to evaluate it as I’m looking at some switch replacements. From the switch side I’ve worked with Cisco for years and it’s what I know better, but some of my network of IT folks have been singing Aruba/procurve praises so I’m doing some testing.
    I think I’ve got a handle in tagged/untagged ports vs trunks. In some testing today I set up my vlans to match my existing setup but I found I couldn’t reach any of them unless I set an IP address on that vlan on the Aruba switch. Is this normal? Is there a guide somewhere I could look at to see how to integrate an Aruba switch into a Cisco environment?
    Thanks!
  • 2.  RE: Aruba switch in Cisco network
    MVP EXPERT
    Posted Nov 25, 2018 01:04 PM
    Hi chamunda
    Here is the hpe networking vs cisco cli reference guide.
    https://support.hpe.com/hpsc/doc/public/display?docId=c04793912
    If you need some help, put your cisco config example her and look what i can do for you.
  • 3.  RE: Aruba switch in Cisco network
    MVP GURU
    Posted Nov 25, 2018 02:00 PM
    To stay a little bit update check this thread which report links to download the very latest 3.3 Edition of the Aruba HPE Networking and Cisco CLI Reference Guide.
  • 4.  RE: Aruba switch in Cisco network
