You will need a 2920/40 or one of the higher end model switches with os 16.04 or higher.
Also some key points to note:
*Make sure the tunneled node vlan Is present on both the switch and the controller.(Also check the status of the vlan)
*Check to see if Jumbo frames are enabled.
*Make sure you have sufficient licenses for each PPTN.
