Wired Intelligent Edge
last person joined: 11 hours ago
Aruba switches 2540 provisioning fails
  • 1.  Aruba switches 2540 provisioning fails
    Posted Nov 18, 2020 06:50 AM
    I am trying to add 4 of my switches into aruba central but it is saying always "Either MAC Address or Serial number is incorrect". I have added the subscription key but as mentioned the device adding is failing. When I check on the switches I can ping f.ex. google.com.
    show activate provision is saying this:
    Aruba-2540-24G-PoEP-4SFPP# show activate provision
    Configuration and Status - Activate Provision Service
    Activate Provision Service : Enabled
    Activate Server Address : devices-v2.arubanetworks.com
    Activation Key : Not Available
    Time Sync Status : Time sync from NTP pool
    Activate DNS Lookup : Success
    Proxy Server DNS Lookup : NA
    Activate Connection Status : Failure
    Error Reason : Activate provision has failed because of
    invalid response received from server with status code : fail-prov-no-device
    Aruba-2540-24G-PoEP-4SFPP# show aruba-central
    Configuration and Status - Aruba Central
    Server URL : None
    Connected : No
    Mode : NA
    Last Disconnect Time : NA
    Error Reason : NA
    Can anyone help to troubleshoot this?
    nikim
  • 2.  RE: Aruba switches 2540 provisioning fails
    Posted Nov 19, 2020 12:49 AM
    Hi
    If you Configure Switches Before add them to Aruba Central then you have to type
    Switch(config)# activate provision enable
    Switch(config)# activate provision force
    Tharindu Pamoda
  • 3.  RE: Aruba switches 2540 provisioning fails
    Posted Dec 06, 2020 03:49 PM
    The problem was something else. The switches were not connected to our MSP activate and thus were failing to join on our tenant. After contacting the aruba support they activated these switches and the problem was solved.
    nikim ab
