Network Management
Aruba Switches Airwave
  • 1.  Aruba Switches Airwave
    Posted Nov 02, 2017 04:59 AM
    Hi!
    I´ve got a question regarding Aruba switches (former procurve) and airwave.
    I know that I can bring them in to Airwave with SNMP / SSH.
    But can I make them connect to a airwave in a similar regard to Instant over internet ? I´ve got a couple of switches where I don´t have a ipsec tunnel between the sites and my airwave server.
    The switches I´m working with in this case is Aruba2530-24/48G
    Is this implemented in a new firmware maybe ? Coming up ?
    It would be a great feature.
  • 2.  RE: Aruba Switches Airwave
    Posted Nov 06, 2017 05:37 AM
    This is what one of my colleagues has to say about this:
    "We support IPSEC tunnel esp for Airwave from 16.02 Firmware.  But our support is limited to TPM devices.
         2530 YA / YB switches currently don’t have support to establish IPSEC tunnel with Aruba Mobility Controller."
  • 3.  RE: Aruba Switches Airwave
    Posted Nov 06, 2017 07:16 AM
    Alright, doesn´t anwer my question though.
    My question was regarding airwave communication between switches and amp-server. And if this is possible to setup in the same regard as with IAP-clusters where I point out a public IP of the amp-server and the devices then communicate with amp by https over the internet. Or if I´m required to have contact with the switches on a routed inside network (snmp).
    Sorry for any confusion.
  • 4.  RE: Aruba Switches Airwave
    Posted Nov 06, 2017 07:54 AM
    Understood.  Asking.
  • 5.  RE: Aruba Switches Airwave
    Posted Nov 06, 2017 10:35 AM
    Unfortunately, those switches cannot initiate traffic across a NAT boundary like Aruba Instant APs to Airwave.  They would need to be polled via SNMP from Airwave over a routed network.
  • 6.  RE: Aruba Switches Airwave
    Posted Nov 07, 2017 05:45 AM
    ok, thank you for the answer.
    Do you know if there is any plans for this feature ? Or maybe it isnt possible...
  • 7.  RE: Aruba Switches Airwave
    Posted Jul 23, 2018 11:13 AM
    is it possible to import and manage aruba switches through a classic (e.g. IPSec) Site-to-Site VPN over public internet? if so, is there any consideration what the communication affect - like MTU size, etc.?!
  • 8.  RE: Aruba Switches Airwave
    Posted Jul 08, 2019 06:34 AM
    Do you now when the switch can be manageable and monitor over internet like IAP ?
  • 9.  RE: Aruba Switches Airwave
    Posted Jul 08, 2019 09:19 AM
    Switches are not currently monitored/managed like IAPs.  That'd be a feature request to submit for switches on the ideas portal.  http://innovate.arubanetworks.com
