Aruba Tunelled Node
  • 1.  Aruba Tunelled Node
    Posted Feb 03, 2013 11:42 PM
    Hi , Has anyone seen any documentation on how tunnelled node works and also how to setup and configure an Aruba Controller and Aruba Switch to utilise tunnelled node. firmware versions required etc.
  • 2.  RE: Aruba Tunelled Node
    Posted Feb 10, 2013 07:25 PM
    It's in the 7.2 user guide - http://support.arubanetworks.com/DesktopModules/Bring2mind/DMX/Download.aspx?TabId=77&DMXModule=512&Command=Core_Download&Method=attachment&EntryId=10228&PortalId=0
    My understanding is the switch forms a gre connection to your controller and creates a "dynamic" vlan for each tunneled port. I had to create and ipsec tunnel, which then tunnels the GRE, as the switch accesses the controller via the Internet (in my case).
    Each tunneled port then uses the 802.1x configuration on the controller
  • 3.  RE: Aruba Tunelled Node
    Posted Feb 11, 2013 03:15 AM
    You can refer to this doc.
    http://www.arubanetworks.com/techdocs/ArubaOS_61/ArubaOS_61_UG/Mux_config.php#XREF_20222_Configuration
    There is an example with configuration as well. This was first support on AOS v6.1.x,
