thats great, i didn't know Aruba Utilities App supported 6GHz
Original Message:
Sent: May 01, 2023 09:27 AM
Subject: Aruba Utilities 6ghz Channels View
I just came across this feature in Aruba Utilities that will show you all available 6ghz channels in the Aruba Utilities App. When you click on the 6Ghz button, or the 5ghz button, the channel pane will switch between 5ghz and 6ghz channels. Please see the screenshots below:
In this view, I am associated to 6ghz channel 101 currently (green channel history ribbon at the top), but the channel graph is showing a list of 5ghz channels along with the channels that have radar due to proximity to an airport. There is a 6ghz button that I can use to switch to the 6ghz channel view:
Please note that you will need an Android device that supports Wifi 6E (in this case a Google Pixel 7) to observe the channels and access points and of course a wifi 6E SSID (in this case a HPE/Aruba 655).
