It has been mentioned that you can use the Aruba utility app to identify radar in a specific location (http://community.arubanetworks.com/t5/Wireless-Access/What-is-the-exact-AP-behavior-when-running-on-a-DFS-channel/m-p/262368#M58893).
I have been running the app but have not been able to find how to do this.
I'm not using the app with airwave or the controller.
Any guidance would be great
Thanks!
The APP uses your GPS location and look it up against a database to see if there is radar there. Attached is an example of what you would see.
Thanks a bunch!
