Aruba VIA and lollipop problem
  • 1.  Aruba VIA and lollipop problem
    Posted May 14, 2015 06:34 AM
    We have VPN VIA users and they cannot connect android 5.x versions. Is there any known issues? Aruba and Android is not like themselves, I think :)
    The last thing I can see from logs is
    May 14 12:01:59 isakmpd[1905]: <103101> <INFO> |ike| IPSEC SA deleted for peer 1010.210.50
    May 14 12:02:04 isakmpd[1905]: <103102> <INFO> |ike| IKE SA deleted for peer 10.10.210.50
    show version
    ArubaOS (MODEL: Aruba6000), Version 6.4.2.4
    Website: http://www.arubanetworks.com
    Copyright (c) 2002-2015, Aruba Networks, Inc.
    Compiled on 2015-01-15 at 18:50:32 PST (build 48122) by p4build
    ROM: System Bootstrap, Version CPBoot 1.2.0.0 (build 20527)
    Built: 2009-01-20 18:56:10
    Built by: p4build@re_client_20527
    Switch uptime is 2 hours 4 minutes 38 seconds
    Reboot Cause: User reboot (Intent:cause:register 78:86:50)
    Supervisor Card
    Processor XLR 732 (revision C4) with 1979M bytes of memory.
    32K bytes of non-volatile configuration memory.
    512M bytes of Supervisor Card System flash (model=CF 512MB).
    Thanks a lot;
  • 2.  RE: Aruba VIA and lollipop problem
    Posted May 14, 2015 07:08 AM
    Problem also occurs with ArubaOS 6.4.2.6 version.
  • 3.  RE: Aruba VIA and lollipop problem
    Posted May 14, 2015 08:10 AM
    I suggest opening a TAC case
  • 4.  RE: Aruba VIA and lollipop problem
    Posted Jun 09, 2015 03:49 AM
    We learned our problem. We have struggled because we entered the same ip for the inner and outer ip in via profile. When we changed the inner ip the problem solved. The latest Via version (2.2.8) works with Android 5.1, even with 5.1.1 versions well.
