Cloud Managed Networks
Aruba VIA failes to establish VPN connection Code:-8949
This thread has been viewed 40 times
  • 1.  Aruba VIA failes to establish VPN connection Code:-8949
    Posted May 16, 2022 11:37 AM
    Just an hour ago VPN users face a problem with the code below.
    I tried this solution, but it didn't help to to solve the issue.
  • 2.  RE: Aruba VIA failes to establish VPN connection Code:-8949
    Posted May 20, 2022 07:13 PM
    VIA version is now upto 4.x. you need to bring it up to that version
    if you are still facing this issue, it is better to contact our support services
  • 3.  RE: Aruba VIA failes to establish VPN connection Code:-8949
    Posted May 22, 2022 02:36 PM
    Thank you for your reply.
    Changing the VIA server certificate from default to aruba_default solved the issue.
    Esmail Ayobinia
  • 4.  RE: Aruba VIA failes to establish VPN connection Code:-8949
    Posted May 22, 2022 07:43 PM
    thats great, but remember to upgrade to the later version of VIA  as 2.x is very old and perhaps not supported
  • 5.  RE: Aruba VIA failes to establish VPN connection Code:-8949
    Posted May 23, 2022 01:35 AM
    yeah, we are using the latest version I think.
    Esmail Ayobinia
