@morjo wrote:
Got a Q about VIA and split tunneling.
As i can read of the white paper on VIA, is that when you enable split tunneling the you have to say what network you want tunneled to you controllere not the other way, so if i want all Microsoft traffic to go out local and all other traffic tunneled to the controllere i need to whitelist all other traffic than microsoft? anyone have a solution for that? cause as i can see you can only whiteliste 32 ip adresse/subnets.
Correct. You have to choose what subnets you want tunneled. You can summarize subnets to avoid listing 32 subnets. For example, if you want your VPN user to send everything on the 10.0.0.0/8 subnet back to your datacenter, you can put that on a single line:
If you have any more questions, the VIA VPN Solution guide is here: https://support.hpe.com/hpesc/public/docDisplay?docId=a00098430en_us
