Aruba VIA transparent login.
  • 1.  Aruba VIA transparent login.
    Posted Nov 05, 2012 08:31 PM
    I already have Aruba VIA setup and working with Active Directory authentication.
    I have a small set of users that I want to instantly sign onto the VIA client anytime they computer is turned on, or when they connect to the Internet. They are all using Windows 7 x64 laptops.
    How would I go about doing this?
  • 2.  RE: Aruba VIA transparent login.
    Posted Nov 05, 2012 09:49 PM
    Autologin can be enabled in the VIA Connection Profile:  "Client Auto-Login".  If this is in enabled in the profile (is by default); if VIA detects an untrusted network, it should initiate and login automatically.
  • 3.  RE: Aruba VIA transparent login.
    Posted Nov 06, 2012 08:49 AM
    And what authentication method would need to be enabled for this to work? NTLM? RADIUS? Certs?
