Aruba Virtual Controller
  • 1.  Aruba Virtual Controller
    Posted Feb 08, 2017 12:59 PM
    HI,
    I want to know if "Aruba Virtual controller" is capable of creating an end to end GRE tunnel for guest traffic.  I have a setup like this.
    Ap--------------vController (in Cloud)-----------DMZ controller -------FW---->
    MD
  • 2.  RE: Aruba Virtual Controller
    Posted Feb 09, 2017 11:03 AM
    Are you referring to the Virtual Mobility Controller?
  • 3.  RE: Aruba Virtual Controller
    Posted Feb 09, 2017 11:16 AM
    Yes, I want to deploy this controller in Azure cloud and one in DMZ.
    MD
  • 4.  RE: Aruba Virtual Controller
    Posted Feb 09, 2017 11:22 AM
    Ok. Yes, the virtual mobility controller is able to create a GRE tunnel to another controller over the Internet.
    I'm not sure why you would want to set it up in this fashion though but I guess you have an idea.
  • 5.  RE: Aruba Virtual Controller
    Posted Feb 09, 2017 11:52 AM
    Thanks for the answer.
    Well we are moving our data center to cloud, we want to move wireless also to same cloud. Like a private wireless cloud.
    Just wanted to confirm if virtual mobility controller to virtual Controller tunnel is possible . What about the other features? Does virtual Controller supports all the classic feature of physical controller or is there some difference?
    MD
  • 6.  RE: Aruba Virtual Controller
    Posted Feb 09, 2017 12:00 PM
    Here's the datasheet. I'm not aware of any restrictions.
  • 7.  RE: Aruba Virtual Controller
    Posted Feb 09, 2017 12:13 PM
    VMC and VMM are not currently supported in Azure (or AWS, GCP, etc).
  • 8.  RE: Aruba Virtual Controller
    Posted Feb 15, 2017 05:57 AM
    Hi ,
    Could you please elaborate why VMC and VMM are not currently supported in Azure? We have VMspace in Azure and a Virtual instance can be deployed on VM. We need to know technically why it is not possible How to achieve this requirement?
    MD
  • 9.  RE: Aruba Virtual Controller
    Posted Apr 02, 2018 09:19 AM
    Any more info on this? Very interested in being about to deploy a mobility controller in either Azure or AWS.
  • 10.  RE: Aruba Virtual Controller
    Posted May 14, 2018 12:02 PM
    Any news on this front?
  • 11.  RE: Aruba Virtual Controller
    Posted Nov 02, 2018 12:35 PM
    Is there any word when VMC and VMM are available in the AWS or Azure Market Place for use in their public cloud offerings?
