Aruba Virtual Mobility Controller - License Tab missing
This thread has been viewed 19 times
  • 1.  Aruba Virtual Mobility Controller - License Tab missing
    Posted Jan 21, 2017 05:37 AM
    does anyone know this issue, that the license tab is missing on Aruba Virtual Mobility Controller?
    See the attachment below.
    Thanks for help!
    Best regards,
    Felix
  • 2.  RE: Aruba Virtual Mobility Controller - License Tab missing
    Posted Jan 21, 2017 08:30 AM
    What option you selected from the initial setup MD or a standalone ?
    MD = Manage Device by Virtual Mobility Master
    Standalone = Standalone Master
    Get Outlook for iOS
  • 3.  RE: Aruba Virtual Mobility Controller - License Tab missing
    Posted Jan 21, 2017 08:36 AM
    Standalone
    Best regards,
    Felix
  • 4.  RE: Aruba Virtual Mobility Controller - License Tab missing
    Posted Jan 21, 2017 12:23 PM
    The license tab will appear after adding the Aruba MC-VA-XX license key via CLI
  • 5.  RE: Aruba Virtual Mobility Controller - License Tab missing
    Posted Mar 02, 2017 04:03 PM
    I am facing the same issue, and they are asking for "Passphrase" which I can't find, because it is under License tab.
    Thanks in advance.
  • 6.  RE: Aruba Virtual Mobility Controller - License Tab missing
    Posted Mar 02, 2017 04:16 PM
    Hello hawada,
    i have a solution for the issue:
    - On the left site (tree horizontaly lines) you can change between Mobillity Master (folder icon), and Mobillity Controller(controller icon). The license tab is only visible under the Mobility Master (folder icon) not under Mobillity Controller.
    - The passphrase in the webinterface is wrong. There are letters missing. You have to connect to console and use "#show license passphrase" and there you will find the correct one!
    Let me know if you need help.
    Felix
  • 7.  RE: Aruba Virtual Mobility Controller - License Tab missing
    Posted Mar 02, 2017 04:20 PM
    Thanks alot it is solved.
  • 8.  RE: Aruba Virtual Mobility Controller - License Tab missing
    Posted Mar 02, 2017 04:49 PM
    Hello Felix.Huber,
    I got the PassPhrase via CLI, but it is not working.
    I am choosing Virtual Mobility controller.
  • 9.  RE: Aruba Virtual Mobility Controller - License Tab missing
    Posted Mar 02, 2017 04:50 PM
    Please send me the message you get.
  • 10.  RE: Aruba Virtual Mobility Controller - License Tab missing
    Posted Mar 02, 2017 04:56 PM
    In order to register JW472AAE, Aruba Cntrlr Per AP Capacity Lic E-LTU, you must first register one of the following Pre-requisite license:JY899AAE,Aruba MC-VA-50 (RW) Cntlr 50 AP E-LTU;JY900AAE,Aruba MC-VA-250 (RW) Cntlr 250 AP E-LTU;JY901AAE,Aruba MC-VA-1K (RW) Cntlr 1K AP E-LTU;JY902AAE,Aruba MC-VA-50 (US) Cntlr 50 AP E-LTU;JY903AAE,Aruba MC-VA-250 (US) Cntlr 250 AP E-LTU;JY904AAE,Aruba MC-VA-1K (US) Cntlr 1K AP E-LTU;JY905AAE,Aruba MC-VA-50 (IL) Cntlr 50 AP E-LTU;JY906AAE,Aruba MC-VA-250 (IL) Cntlr 250 AP E-LTU;JY907AAE,Aruba MC-VA-1K (IL) Cntlr 1K AP E-LTU;JY908AAE,Aruba MC-VA-50 (JP) Cntlr 50 AP E-LTU;JY909AAE,Aruba MC-VA-250 (JP) Cntlr 250 AP E-LTU;JY910AAE,Aruba MC-VA-1K (JP) Cntlr 1K AP E-LTU;JY911AAE,Aruba MC-VA-50 (EG) Cntlr 50 AP E-LTU;JY912AAE,Aruba MC-VA-250 (EG) Cntlr 250AP E-LTU;JY913AAE,Aruba MC-VA-1K (EG) Cntlr 1K AP E-LTU
  • 11.  RE: Aruba Virtual Mobility Controller - License Tab missing
    Posted Mar 02, 2017 04:58 PM
    What type of license do you have ordered? I think ou have forgot the MC-VA-License... ?
    Can you share your order?
  • 12.  RE: Aruba Virtual Mobility Controller - License Tab missing
    Posted Mar 02, 2017 05:01 PM
    it is a trial license.
